White Smoke?
Old Nov 19, 2007 | 08:55 AM
my4runner's Avatar
White Smoke?
What causes white smoke when you start the truck for the first time each day, then after doesnt smoke again? (Only in the mornings) Thanks
Old Nov 19, 2007 | 09:02 AM
Georgiadave's Avatar
Worn or defective valve guides are a likely suspect.
Probably it is oil leaking past the valve guides overnight and accumulating on the valve heads and cylinder walls. When you start the engine, the oil burns off. You may also notice this when you are idling and stopped and then accelerate.
Old Nov 19, 2007 | 09:04 AM
infiltrator's Avatar
yeah, this happens with me, how can we fix it? is it bad?
Old Nov 19, 2007 | 09:05 AM
Turbo4Runner's Avatar
I have always heard (and my experiences have supported this so far):
White smoke = Burning Coolant
Blue Smoke = Burning Oil.
Old Nov 19, 2007 | 09:13 AM
MMA_Alex's Avatar
yeah white smoke is usually water/coolant. oil burns black.
check the coolant and the oil.
when its cold you'll get some white smoke when you start it up typically, and thats not an issue.
Old Nov 19, 2007 | 09:18 AM
mt_goat's Avatar
X2, try starting in the morning then shut it down quickly and pull your plugs and look for one wet with coolant.
Old Nov 19, 2007 | 09:25 AM
keithguts's Avatar
What is the temp where you are? If it's cold outside, it is normal for the rig to smoke when you 1st start it up. Mine does it all the time, but it is only the hot air hitting the cold air. I think I said that right.
Old Nov 19, 2007 | 10:20 AM
my4runner's Avatar
Its actually warm here in El Paso Texas, it doesnt smoke at all during the day, stop and goes either!! Thanks my friends
Old Nov 19, 2007 | 10:33 AM
aviator's Avatar
warm during day but what does the temp drop to at night? It might just be the "cold start" smoke we see up here in the NE. remeber your truck will have "cold soaked" over night so even if the air is warm when you leave in the a.m. the engine could still be quite cold.
Old Nov 19, 2007 | 10:51 AM
keithguts's Avatar
It sounds to me like you haven't got anything to worry about. If it dosn't do it after the 1st start, I think it is just the cold start. The hot air hitting the cold air seems to be the problem in this case. I might be wrong, but mine has been doing that since I got her. Not as much in the summer, but still a small amount in the morning in hot weather, but alot more as it gets colder.
Old Nov 19, 2007 | 11:55 AM
billmaness's Avatar
I assume that you have anti-freeze mixture in the coolant system (not straight water). If you are burning oil or antifreeze, the tailpipe would be greasy inside. Check with finger. This smoke would also linger in the air. The white smoke in the morning that quickly "disolves" after leaving the tailpipe is water vapor/condensation from temperture changes inside the system. This is more noticeable in the morning when the humidity is higher and is normal. You will also have clear water (condensation) dripping from the tailpipe. This is why short trips will rust out the muffler/tailpipe.
Old Nov 19, 2007 | 12:00 PM
keithguts's Avatar
Well said.........................
Old Nov 19, 2007 | 12:43 PM
misterzee's Avatar
If the engine seems otherwise healthy, i.e. no oil-water mix, and the cloud is just upon cold start and only lasts a few seconds, its most likely the oil that gets in past worn/hardened valve guide seals. You can change em, or just have your friends look the other way when you start up. ;-)
Old Nov 19, 2007 | 12:45 PM
85toy's Avatar
its cold outside with a lot of moisture in the air its just water burning.
Old Nov 20, 2007 | 10:27 AM
Some diagnostics
Look at the plugs and into the combustion chambers before you start the engine in the morning. Look for oil or water on or in one or more.
Then do a compression check. Low or no compresson means a blown head gasket or a leak.
Test for CO2 in the coolant. This can be done with a kit.
I still lean to worn valve guides and seals. Oil smoke is white, fuel is black.
Good luck with this matter.
Old Nov 20, 2007 | 12:36 PM
dcg9381's Avatar
Two things to check:
1) Does it smell like coolant?
2) Are you losing water - at all?
A HG can go, dump water into the cylinder(s) and you'll never see it in the oil pan. You will be able to see it if you pull the plugs and look at the top of the piston - pistons picking up water won't have nearly as much carbon on them.
Truck may not run any differently, may not show much for other issues....
Old Nov 20, 2007 | 01:56 PM
bigarms23's Avatar
its either oil leaking into cylinders but also make sure your exhaust manifold it titened
Old Nov 21, 2007 | 01:46 AM
corvey's Avatar
Valve Guides...
Does it smell sweet like antifreeze (assuming you have have antifreeze in your radiator)?
If not, Valve Guides for sure...
Old Nov 21, 2007 | 06:27 AM
my4runner's Avatar
Thanks everyone, it was the valve guides, had all the valves and guides replaced, no more smoke!!!!!!!!!!!!!!!!!!
Old Jan 16, 2008 | 08:18 PM
Travisfab's Avatar
My white smoke smells more like coolant, headgasket?
