Where can I get brake shims?
Old 01-23-2010, 04:31 PM
Crawdad's Avatar
Mine are missing, and no auto parts store nearby has them!
Old 01-23-2010, 05:11 PM
habanero's Avatar
Beck/arnley makes some 084-2045, but double check that number. Amazon has them. Guess you've got squealing?
Old 01-23-2010, 05:26 PM
betelnut's Avatar
Shims are usually sold as a set with the pads. AutoZone brake pads come with a single shim, not like factory spec which calls for two, but doubtless intended to replace the double factory shims.
You could just buy a set of pads, use just the shims, and keep the pads around until next brake job.
Don't forget to get anti-squeal brake lube at the same time.
Blamalam
03-12-2022 07:34 AM
1uzRunner
63
11-10-2018 03:58 PM
old87yota
09-09-2015 12:39 PM
Scatterbrain
09-03-2015 06:46 PM
Peevedkitten
11
08-31-2015 06:57 PM
Quick Reply: Where can I get brake shims?
