Wheel "wobble"
Wheel "wobble"
Need some help on what to search for ...
When I was putting on the 'wheeling tires, I noticed the driver's side front wheel "rocks" when pushed at 12 and 6, but not at 9 and 3.
Balljoints? Wheel bearings? Tie rods?
If you are getting a loose feeling (like your lugnuts are loose), your bearings just need to be repacked. A bad ball joint would require a lot more pressure to notice the play (you'd need to pry up from underneath your tire with a bar).
Tie rod play would be at 9 and 3.
I finally found the instructions in the online FSM ... is this really something I should do myself or would it be worth it to pay someone? Looks like there's not a whole lot too it, but seems kinda finicky about drag and torques and stuff...
The truck has about 190k miles and I wheel pretty frequently. Would it be a good idea to just replace the bearings while I'm in there?
Originally Posted by Toyopnoy
Sorry to hijack, will Lithium based grease be good for this?
http://www.off-road.com/toyota/wheel_bearing.html
Originally Posted by ChickenLover
Been there, done that many times. Repack the bearings.
Originally Posted by lVlr_87
36mm socket for the spindle nuts. Use Moly grease.
Originally Posted by Asha'man
2 1/4" works too. I got mine at Sears for about $22.
Brian
Brian
OK, I FINALLY found a brass punch, (Sears, local big hardware store, Advance, Autozone, Tractor Supply didn't have one or even any brass stock I could use) so I think I have everything:
2-1/8" socket + 3/4"-> 1/2" drive adapter
1/2" drive torque wrench
3/4" brass punch
Inner oil seal
inner bearing
inner race
outer bearing
grease
I forgot to get the spindle lockwasher. I'm going to see if anywhere has it in stock after work - the FSM says it's a nonreusable part, any thoughts?
Doesn't look like there is an outer seal - is that correct?
3/4" brass punch
Inner oil seal
inner bearing
inner race
outer bearing
grease
And as far as I remember, no outer seal. That part is sealed off with the ADD flange or your manual hubs.
Did it tonight, took 2.5 hrs, including having to go get the neighbor to help me bleed the brakes.
One little hint - clean ALL the grease out of the hub and you'll see little notches where you can get your brass punch in to knock the races out easier.
Up&Down
08-05-2015 06:20 AM
Luvmeye22re
08-04-2015 03:53 PM
skoti89
07-06-2015 07:45 PM
