what is the ultimate backspacing for R15 with a 32" AT tire
Old 01-12-2006, 03:51 PM
hill's Avatar
what would the best backspacing be for my 32" R15 x 11.5 yoko tires?
3.5? 3.75? 4? and why is it better then stock bs?
Old 01-12-2006, 06:43 PM
hill's Avatar
there is a guy selling some 15 x 8 with a 3.5" bs procomp rock crawlers around town for $50 a wheel.
Is this a good deal? will 3.5"bs work? i dont even know what the stock backspacing is on my toyota rims...any help????
Old 01-12-2006, 07:41 PM
Swissdrums's Avatar
I know my AR rockcrawlers have 3.75 back spacing...looks like a good fit with that, no problems...
I'm pretty sure stock is 3.75 as well...u might have to check on that.
-mike
Old 01-12-2006, 07:45 PM
hill's Avatar
so would 3.5 backspacing actually make the tire fit further inside or outside the wheel well?
Old 01-12-2006, 07:46 PM
rocket's Avatar
Your stock BS is either 4.75" or 4.5"
Less backspacing will give you a wider stance, can reduce or eliminate rubbing bigger tires, makes for less chance of a roll over, and looks better/more agressive.
3.75" BS is very common. 3.5" will just stick out a tiny bit more. If your after a wider look, you'll definitely notice it. Will it work? Yes.
Really, theres no such thing as "ultimate backspacing" but 3.75 BS seems to be the most favored, plus they're easy to find or replace.
Old 01-12-2006, 07:49 PM
hill's Avatar
rocket..thank you for an awesome response...cheers....
colin
Old 01-12-2006, 07:53 PM
rocket's Avatar
No problem!
Its not the best example but heres a pic i have with 33x10.50 tires on 4" backspaced rims...
Old 01-12-2006, 07:56 PM
hill's Avatar
what are the drawbacks of a slightly wider stance...lets say with a 3.5 BS rim?
Old 01-12-2006, 08:09 PM
rocket's Avatar
I'm not aware of any drawbacks other than you *might* have a chance of rubbing your tires on the outter fender seem when flexed/stuffed. I don't think you'd have to worry about that with 3.5" BS though.
Old 01-13-2006, 05:18 AM
Buck01's Avatar
ok this might be a silly question but here goes. How do you measure backspacing?
lay the rime down backside up, have a level across the rim and measure to the back of the mounting surface????
Old 01-13-2006, 06:37 AM
hill's Avatar
yeppers
Old 01-13-2006, 05:30 PM
kyle_22r's Avatar
less backspace means more load on the wheel bearings, not to mention if you put something with insanely low backspace on your truck(like 2.5" the crawler guys use) you'd best put on some chrome mud flaps and dingle ball fringe on the inside of the truck
1uzRunner
63
11-10-2018 03:58 PM
firstgen88
10-07-2015 04:53 PM
Williamemslie
14
10-05-2015 09:28 AM
128keaton
09-03-2015 05:09 PM
matthew138
09-03-2015 08:21 AM
Quick Reply: what is the ultimate backspacing for R15 with a 32" AT tire
