What is source and correct value of STA signal at ECU
Old 04-01-2012, 07:36 PM
surfin cj7's Avatar
Trying to troubleshoot a no start issue outlined here:
https://www.yotatech.com/forums/f116...-start-251387/
Want to verify the STA input to ECU described here:
http://www.autoshop101.com/forms/h24.pdf
Is it just battery voltage from the ignition switch once the clutch is depressed?
Matt
Old 04-02-2012, 03:35 AM
rustypigeon's Avatar
You should have at least 6 volts between ecu terminals STA and E1 when the engine is cranking. When you have the ignition in the start position and the clutch is pressed, the circuit is closed allowing positive voltage to flow to the ecu Sta input.
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
PBRaddict#1
09-14-2015 10:31 AM
O Holy P
08-18-2015 02:33 PM
cr@ves4wheelin
3.4 Swaps
08-17-2015 07:47 AM
mund1011
08-16-2015 07:10 AM
Quick Reply: What is source and correct value of STA signal at ECU
