What gears do I have in my hilux surf?
Old 10-30-2007, 06:07 AM
frozenSurf's Avatar
Question What gears do I have in my hilux surf?
I have a 1986 Hilux surf with the 2lt. Someone told me this model came with 4:10's from the factory. I'm thinking of running a set of 33's on it this summer, will these be too much for the little diesel?
thanks in advance,
frozen
__________________
1986 Hilux Surf 2.4L turbo diesel running on B100 + WVO
Old 10-30-2007, 07:38 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Run a search on gear ratio. You'll find out how exactly to check it for your vehicle. Probably is 4.10's, though. Plus, you'll get a lot of experiences with what other have found. However, since you have the diesel it might make a difference....as opposed to a non-diesel....since the diesels have better low end torque. It usually makes some difference any time you change the gearing ratio. How much is determined by how much power you're already putting out and how much you're changing the ratio. Maybe someone with diesel experience can chime in.
Old 10-30-2007, 02:55 PM
88-surf's Avatar
if it ses g285 on the tin thingy that ses ur chassis number year bla bla bla on the fire wall under the bonet ull have 8.0 inch ring gear, and 4.30 gears, and 4 Pinion LSD. like me
Old 10-30-2007, 02:57 PM
thook's Avatar
You have 4.30's? With a 5spd or automatic?
Old 10-30-2007, 07:03 PM
frozenSurf's Avatar
4.30's with a w56 5 speed. The engine (2LT) is running 2 1/2" exhaust, cold air intake, intercooled, and 10 lbs of boost. Anyone think that this is enough to push 33's?
-forzen
Old 10-30-2007, 07:11 PM
thook's Avatar
Well then, you might be just fine. 4.30's is definitely lower than 4.10's. Not much, but definitely lower. And considering what you're power plant consists of....
Speaking of which...
Those surfs came STOCK with diesels, 5spd's, AND 4.30's? I'm soooo envious. I can't stand our gov't. Bastards.
Old 11-29-2007, 11:42 AM
Belize Off Road Team's Avatar
hilux-surf.co.uk, another forum website like YT but all about the HSurfs for us Surf owners
Old 12-02-2007, 06:49 AM
4runner4ever's Avatar
I had a few Hilux diesels myself. Actually lots of them.
All came with 4.3 gears (4WD) or 4.1 gears (2WD) and a manual W56 5 speed.
Rear LSD was optional, only on SR5's I think.
O yeah, and optional solid FA up to '95 or '96.
Old 12-02-2007, 12:48 PM
Sonofmayhem's Avatar
Stop rubbing it in!
Old 12-02-2007, 01:00 PM
b.miller123's Avatar
They forgot to tell us about how they could get the diesels with a solid front axle, AND in a double cab
Old 07-08-2013, 09:09 PM
Myat Naung's Avatar
somebody know! how to adjust the gear changing timing for the hilux surf 1995 model kzn130?
norcal98
08-10-2015 06:20 AM
thefishguy77
07-30-2015 10:59 AM
Backcountry411
Diesel Swaps
07-29-2015 01:33 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
jgallo1
07-22-2015 04:21 AM
Quick Reply: What gears do I have in my hilux surf?
