What is the gas tank size for 1st gen 4runners?
Old 06-21-2007, 08:16 PM
eightnine's Avatar
I know this is a stupid question but im asking because i want to know how much gas is remaining once the fuel light pops up. It just took me 51 litres to fill up about after the light pops up.
Old 06-21-2007, 09:01 PM
eightnine's Avatar
found out it has a 14.3G/65litre tank. Found it off the search feature, sorry
Old 06-21-2007, 09:31 PM
deathrunner's Avatar
I could be wrong, but I believe mine is 17.2
Old 06-21-2007, 10:00 PM
Staff
DeathCougar's Avatar
17.2 here as well
Old 06-21-2007, 11:51 PM
Diesel_Freak's Avatar
I thought mine was 16.6 gal, not sure about them there litre's...
Old 06-22-2007, 12:06 AM
91muddog's Avatar
only way to be sir eis run er all the way dry, and drag er tot he station and fill er up!
Old 06-22-2007, 02:27 AM
89-4Runner's Avatar
do all 1st gens have a low fuel light? I know my 2nd gen did, but assumed my 1st gen didn't cuz I've never seen it on?
Old 06-22-2007, 03:57 AM
Corbit's Avatar
My first gen had a fuel light that would come on when I had about a gallon left, and mine had the 17+ also. MPG = 18 - 22
Old 06-22-2007, 07:59 AM
89-4Runner's Avatar
should I run it out of gas to see if my low fuel light comes on? (JK) I've got the SR5 guages, so I would assume I should have the light too, no? anyone have this dash without a low fuel light?
Old 06-22-2007, 08:08 AM
DudeBud's Avatar
my 88 sr5 cluster had a low fuel light.. the other sr5 cluster that I had didn't..
Old 06-22-2007, 08:10 AM
frodin1's Avatar
I dont know but my 3rd Gen seems like it holds a half gallon. I actually was trying to figure out if I could get a fuel cell and put it in there??
Old 06-22-2007, 09:07 AM
eightnine's Avatar
yeah it has to have one it may just be burned out. The way to check is to turn ur key to the ON position right before you crank it. All the lights on the dash should turn on and if the gas light doesnt pop up it means that its burned out. Even my basic speedocluster with no tach has the light.
Old 06-22-2007, 09:09 AM
eightnine's Avatar
i have a feeling it depends on whether you have the 22re or 3.slow. Cause iv heard of some being 17.3Gallons and others being 14.3. Im gona check my OG owners manual to see if it says anything
Old 06-22-2007, 09:20 AM
ewong's Avatar
There's a post on PIRATE4x4 that has Pics on how to tell which tank you have.
I vaguley recall its 6" vs 8" from the seam to the bottom of the tank measured near where the drive shaft passes the tank...
Old 06-22-2007, 09:26 AM
netwt12's Avatar
both 14 & 17 gallon tanks were offered. they have different pump hanger assemblys and different sending units. the pumps iirc are the same or can easily be modified to work.
Old 06-22-2007, 10:35 AM
DudeBud's Avatar
are you sure about that because all my basic cluster did not have a light nor a place to put a bulb it the back.
Old 06-22-2007, 11:00 AM
eightnine's Avatar
im going out right now so il take a pic of the cluster with all the lights turned on
Old 06-22-2007, 11:11 AM
CyMoN's Avatar
mine is 17 and the light turns on at 15 and my aux tank that is above the spare holds 10 gallons
Old 06-22-2007, 12:34 PM
DudeBud's Avatar
ok.. maybe its a newer cluster thing, but then again my 88 standard cluster had non.
Old 06-22-2007, 12:42 PM
Greg_Canada's Avatar
My light is burnt out, but i usually drive to where it goes below the "E" line... which means it takes 55-58 litres to fill up.
Oh, and i think they all have the same size tank, just there is two types of gallons, imperial and standard
65 liters = 14.2979952 Imperial gallons
65 liters = 17.1711833 US gallons
Quick Reply: What is the gas tank size for 1st gen 4runners?
