what caused the headgasket for the 3vz-e
Here's a good post by EB on the subject. https://www.yotatech.com/forums/show...6&postcount=18
TN explained it the closest to as the way i understand and was explaind to by the mechanic who did my last hg. toyotas have aluminum heads and a cast iron block. When u heat motor up (especially overheat) the castiron expands and aluminun dosent witch just crushes the gasket from the exapansion. so basically thats toyotas poor design. Im not sure why 3.0 are so notorius and not the 4 cyl. My mechanic said its very very common to expect to do a head gasket job every 80,000 miles on the 3vz-e motors
Aluminum expands MORE then cast.
Fred
I ran across this the other day and found it interesting.
http://www.aa1car.com/library/2005/ic010532.htm
Besides a must read for everyone concerned about HG's in particular, it should also be a must read for all the silly rocket scientist here that claim it's ok to disable/remove the EGR..
Fred
Contributing factors include an inoperative EGR system (which helps cool combustion temperatures under load),
#26
Maybe a day late and a dollar short, but I have plenty of experience rebuilding Ford FE motors too, 10:1 compression motors, cast iron block and aluminum(aftermarket, but still aluminum) heads, and same head bolt pattern as the 3vz I just recently did a hg job on(plus 2 more bolts a side 'cause it's a V8). There's lots of guys doin heavy towing/hauling, drag racing, all sorts of heavy duty and abusive driving without hg problems. I second the crossover idea and the poor material idea, seein as how my hg was fine on my Toy, even though the recall was done at about 54,000 miles and it now has 188,000 on it. I only had to remove the heads to extract a broken off spark plug!
some drunk guy
08-03-2021 06:09 PM
_Nicco_
09-21-2015 03:06 PM
LotOMiles
09-14-2015 11:45 PM
