Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
__________________
340k mile, mud slinging, hell raisin, daily driven yota. And still going strong |
#2 (permalink) |
Personal
Sales Rating: (0)
Fuel Pressure Regulator Vacuum Switching Valve (FPR VSV)
Yes.
__________________
Fairbanks Offroad Lions 2000 Tundra Ex-cab| 2UZ-FE| 126K miles| SR5 TRD|2" front spacers| custom sliders and rear bumper| Beater with a heater '95 4runner|22re|5spd|152K miles| 2" BL| 33x12.5 m/t |anti-sway bars removed f/r| Warn manual hubs| Yakima roof rack| PaceSetter header| 2.25" exhaust| XLPerformance muffler|Engine in midst of a rebuild '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
okay. thank you!!
__________________
#4 (permalink) |
Personal
Sales Rating: (0)
X 2, what he said. ITs a VSV or TVV. I have an extra identical plug on mine thats for the A/c I think. But i dont have the option at all in my truck for A/c. If thats the case for you maybe you could cut and splice that connector to fit. Just a thought
and yes that will cause it not to run. Good luck
#5 (permalink) |
Personal
Sales Rating: (0)
[OP]
Well I got a pig tail for it and wired it in. Still no start. I've replaced the fuel pump already. I know I'm getting fuel up to the fuel rail.
__________________
#6 (permalink) |
Personal
Sales Rating: (0)
Blown fuses then?
__________________
1987 Toyota Pickup DLX. 30" Cooper Discoverer S/T's. 1" AAL lift and Tbar crank. and two KC HiLites. IFS Club #5 1978 Camaro Z28, 454 Big Block V8 with a 4 Speed. |
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
I have checked all my fuses. They're all good. And I did the, jumper wire from the FP to the B+ in the diag box, deal.
__________________
#8 (permalink) |
Personal
Sales Rating: (0)
__________________
"Ya gotta love 'em, 'cuz it's illegal ta kill 'em." - Ron Shirley from Lizard Lick Towing & Recovery of NC. I'm Cuckoo For YOTA Trucks! Putting theTECH inYOTATECH since 2007 Last edited by MudHippy; 01-20-2012 at 10:11 AM. |
#9 (permalink) |
Personal
Sales Rating: (0)
Just looked at my '95 22re and pictures/memory of my '88 22re.
Blue is the FPR VSV. Red is the PAIR/AS VSV. I had to replace the RED PAIR VSV on my '88 to get it I/M'ed. I swapped the RED VSV (PAIR) from my '93 22re onto my '88 to do so.
__________________
#10 (permalink) |
Personal
Sales Rating: (0)
From the pics it looks like a 22re - what year? What have you checked other than replacing fuel pump - did you check for spark?
Look for power on +B in the check connector when ignition on. If no, double-check EFI fuse on passenger inner fender, and IGN fuse in drivers kick (at least, that's where it is on my 89). If the fuses are good and no power on +B, probably either bad EFI Main Relay or bad ignition switch, possibly bad wiring connection. If there's power at the IGN fuse when ignition switch is on, then the switch is probably okay and it's likely to be the relay. If power on +B, check for spark. The least likely to shock yourself way is to pull a wire from a single plug, plug an extra spark plug into the cable and set the plug where the base (not center electrode) is in contact with a good engine ground and have a helper crank it. If no spark, check for power on positive terminal of ignition coil when ignition is on. If no power, either bad ignition switch, or bad wiring connection/blown fusible link. If no spark but there IS power to the coil, most likely bad coil, possibly bad igniter or bad connection or blown signal coil in the distrib, or bad connection TO the signal coil. To check the ignition coil, make sure ignition off & disconnect all wires to coil. Between positive & neg terminals of coil should be (assuming later model 22re) .36 to .55 ohms (that's right - about half an ohm). Between positive terminal and high tension terminal (where cable attaches) should be between 9,000 - 15,400 ohms (9k -15.4k ohms). Unfortunately it's possible for a coil to pass this test and still be bad. But it's not real common. The best test is on a hot coil using the hot specs but that's a bit difficult if it won't start. http://www.ncttora.com/fsm/1993/ignition/4onvehicl.pdf The resistance of the signal coil in the distrib should be 185-275 ohms. Air gap between the signal rotor lobes and the signal coil projection should be .2 - .4 mm (0.008 - 0.016 in) If spark okay, check that injectors are firing. Easiest way is to place the metal rod of a mechanics stethoscope (usually cheap at any parts store) against the metal body of an injector while a helper cranks it. If it's firing the clicks will be loud and clear. If no clicks, check any wire connected to any injector for power when ignition is on. (They should all have power when ignition is on; the ecu fires them by grounding them.) If no power, either bad ignition switch, or bad wiring between fusible link and switch, or between switch and injectors. On 88 and earlier models there is an inline resistor between switch & injectors that could be bad. If spark okay & injectors are firing, check fuel pressure. http://www.ncttora.com/fsm/1993/engine/28fuelpump.pdf If fuel pressure, spark & injector firing okay, check compression, then valve & ignition timing, making sure distrib isn't 180 degrees off. This post has some links that may be useful: http://www.yotatech.com/f116/annoyin.../#post51134917
__________________
1989 V6 4x4 X-Cab 5spd 288k miles, Borla cat-back, K&N Filtercharger, 30x9.5 Bridgestone Dueler A/T REVOs Last edited by sb5walker; 01-20-2012 at 09:44 AM. |
