what 200k miles does to an o2 sensor
Old 08-11-2007, 09:13 PM
brythefly's Avatar
had a check light throwing code 21 so i bought a new o2 sensor today, check out my old one haha.
truck was sluggish and seemed lean and gas mpg was TERRIBLE
Needless to say, the truck runs awsome now.
Old 08-11-2007, 09:29 PM
Yota Runner's Avatar
WOW! What kind of rig was this on? Maybe I should replace mine....Hmmm
Old 08-11-2007, 09:35 PM
infiltrator's Avatar
did you do the seafoam? where is taht sensor located?
Old 08-12-2007, 05:07 AM
kenwoodrunner's Avatar
check your cat convertor. if the sensor was throwing your system rich your cat's life will have been shortened or killed
Old 08-12-2007, 06:40 AM
brythefly's Avatar
Old 08-12-2007, 06:44 AM
brythefly's Avatar
i just put on a flowmaster 40 serioes so i took the cat out of my system all together at the same time, and it was on my 1989 toyota pickup 3vze.
sensor was in the exhaust right before where my cat used to be.
What is seafoam, never heard of it...???
also, as soon as i replaced it, the check light went off, so i should be good to go, performance gains were very unpredictable, runs way better than i could ever have imagined.
Old 08-12-2007, 06:58 AM
basr5's Avatar
seafoam is an engine cleaner it is the best , what kinda yota was that 02 sen. on i have a 95 4runner please PM me with what kinda yota that o2 was on and what brand of 02 your just bought?
Old 08-12-2007, 01:42 PM
langzaiguy's Avatar
How hard was it to take off the exhaust pipe and what method did you use?
Old 08-12-2007, 02:04 PM
95RunnerSR5's Avatar
it simply unbolts with 14mm bolts/nuts
Old 08-12-2007, 03:49 PM
tyang's Avatar
yeah its only held on by 3 14mm bolts, i should prob check out my o2 sensor truck running like and horrible gas mileage. I pulled off the whole exaust system when i did my clutch a few months ago and saw that the bolts holding on the O2 sensors is hella corroded on. So seafoam is suppose to help get it off easier?
Old 08-12-2007, 04:40 PM
Godzilla's Avatar
no seafoam is like a fuel injector cleaner/engine cleaner and etc...not much will make the bolts easier to get off except for a wire brush and some heat, and maybe some penetrant
Old 08-12-2007, 05:05 PM
brythefly's Avatar
mine only had two nuts holding it on, but i used vicegrips to get them off becasue mine were wasted. Also used a lot of PB blast. Just replaced the nuts afterward.
ill post mileage boosts in about a week or two because im currently painting my truck so wont be driving this week
Old 08-13-2007, 05:37 PM
andrew241's Avatar
Mine looked like that before the cat on my 94 at 110k. Scarey stuff lol
Old 08-14-2007, 09:22 AM
Jay351's Avatar
*thread jack*
Need to replace my o2 sensor and the bolts, they are completly rounded off.
Anybody know what size/thread type they are so I can go to the hardware store and get some new ones?
Old 08-14-2007, 09:41 AM
Godzilla's Avatar
https://www.yotatech.com/forums/f2/02-sensor-qs-65796/
https://www.yotatech.com/forums/f2/o...ut-bolt-16010/
a good suggestion if yours is the stud with the nut, then its best to try and get that off with some penetrant soaking. If you break that stud, things will suck. A good option is to use your dremel and cut through the nut to break the nut off. also wire brush it to help.
moparbay
03-10-2023 03:50 PM
Firefightersink15
11-23-2015 10:32 PM
charlie_fong
09-27-2015 10:06 PM
Rickstwowheels
09-21-2015 05:21 AM
larrys93pickup
09-17-2015 07:05 PM
Quick Reply: what 200k miles does to an o2 sensor
