Weird throttle response
Old 07-19-2009, 05:13 PM
mt4runner's Avatar
Coming back from the mountains yesterday had a weird thing happen. Going down a steep, rocky two-track in low range,('91 runner 3.0 5 speed) 2nd and sometimes 3rd gear, when I came out of an idle on the (somewhat) smoother stretches, and held about 2000-2200 rpm, the 'Runner started bucking, just like I was on and then off and then on the gas, real fast. At first I thought it was me not being able to keep steady on the go pedal due to the rough road, but turns out that I was, in fact, holding steady. I didn't really look at the tach when this was going on, because I didn't really want to take my eyes off the road,(did I mention that the "road" was a little nasty?), but I'm going to guess the engine fluctuated about 500 to 700 rpm's. Any ideas' as to what is going on would be appreciated!
Regards, Rick
Old 07-19-2009, 05:28 PM
iamsuperbleeder's Avatar
check your grounds; maybe one's loose and is vibrating around during the rough road traveling
Old 07-19-2009, 05:44 PM
abecedarian's Avatar
also check for any loose or corroded connections around the igniter and distributor.
and if it happens again, look at the tach.
Old 07-19-2009, 07:31 PM
mt4runner's Avatar
Thanks for the quick replys! I will check the grounds. I was thinking that it might be in the fuel delivery system, but I'd rather it be a ground somewhere.....easier fix!
Rick
some drunk guy
08-03-2021 06:09 PM
shredder4286
10-01-2015 01:09 PM
Sam hain
19
09-30-2015 08:25 AM
Boomer8404
09-24-2015 01:12 PM
Shaun Crystal Gomban
09-20-2015 11:16 PM
Quick Reply: Weird throttle response
