vibrating a lot on highway 1990 toyota 2wd
ok i have been having this vibrating thing going on for sometime.
going over 50mph on highway the truck vibrates really bad i can feel it in my seat and floor board vibrates.
the u joints are nice and tight and have a brand new trans mount.
ok i have changed:
got new tires.
got a wheel alignment.
got brand new front wheel bearings.
and it still vibates a lot .. what to do now?
help
where do i go now?
let me know thanks
alex
ok i have changed:
got new tires.
help
where do i go now?
let me know thanks
alex
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
could 1 of your rims be out of round, or bent? Do you feel any kind of roughness in or thru the steering wheel? You might have a bad motor mount. Do you really feel the vibration when accelerating, or just cruising over 50? Check your cv joints.....
Had same problem on a new set of tires one month ago. Finally had a road force balance done and they found one of the new tires out of spec. Tire Rack took the bad one back, sent me a new one and paid for the balance and remounting. All this after I had a new drive shaft center bearing installed. Drives good now at all speeds. I will soon be changing my wheel bearings, and u joints just because.
Ok i got a one peice drivelive, new tires new front wheel berrings
the vibrating is in the rear
i rotated my tires from back to front vice veasa
u joints are tight . It does it sometime on the highway going 50 mph
it seems to do it more when a make a lane change or going around a turn on the highway
it all so seems to do it more to when going up hill a little on the high way and down hill to on highway
i did not take the bolt out of the bottom of the shock let on the rear end
would a bad rear shock cause it to vibrate?
