Valve Tap
Old 08-29-2006, 04:34 PM
MMA_Alex's Avatar
Valve Tap
I recently changed over to mobil 1 (10w-30), and a purolator pure one filter. I let it sit for a couple days, and when i started it up the valve tap seemed way louder than usual. Any ideas as to what my issue could be? Im thinking perhaps the oil filter is too restrictive, and maybe i should switch to a less restrictive filter? Should i re-adjust the valve clearances to smaller gaps because im running synth? any ideas?
Old 08-29-2006, 04:41 PM
86SR522REEFI's Avatar
Are you sure its that valves that are ticking? My injectors tick pretty bad. It almost sounds like a valve tap.
Old 08-29-2006, 04:53 PM
MMA_Alex's Avatar
it could be, it just seems way louder since i made the change over
Old 08-29-2006, 04:58 PM
Do you have acess to a mechanics stethascope? Listen to the valvetrain. Im pretty sure its the injectors.
Old 08-29-2006, 05:02 PM
Elton's Avatar
i think its cuz the oil is thinner.... how many miles do you have ?
Old 08-29-2006, 05:06 PM
I dont think that would do it. It might. What weight did you have before?
MMA_Alex's Avatar
just rolled over to 86k this week. a 10w30 synth is the same thickness as a 10w30 dino. I've been running 10w-30 with no issues since i bought the truck at 83k. I changed to valvoline dino right after I got it, and just switched to mobil 1 this week. I havent listened to it with the hood open so perhaps i should listen and see if its coming from the fuel rail side? I know most of my cold valve tap from before was coming from the exhaust side
Old 08-29-2006, 05:09 PM
Elton's Avatar
you have 86k miles wow trucks still a baby the oil anit the problem
Old 08-30-2006, 11:48 PM
84sr5yoty's Avatar
I don't know what the heck it's with mobile 1, but my valves always got nosier with that stuff. That includes my honda accord as well. I bet their oil is a little on the thin side.
Old 08-31-2006, 02:19 AM
TNRabbit's Avatar
What oil filter were you using before? Are you sure you have the correct filter? Is the engine noise normal after the oil pressure builds up? Sounds like maybe the anti-drainback valve in the filter isn't working properly...did you only change oil & filter? No other modifications?
Old 09-01-2006, 01:57 PM
MMA_Alex's Avatar
sorry i was out of town for 2 days. I dont know about warm as i havent had the truck warmed up since the day after i changed it. I was using the regular purolator before, and i switched to the pureone. I never had any issues with the old filter. I did start it up today, and it didnt sound as loud. Maybe its just in my head. I should have a chance to go warm it up sometime early next week (I've been in freshman orientation all this week)
Old 09-01-2006, 02:13 PM
Snorkeldepth's Avatar
I second the suggestion to get a mechanics stethoscope. They're only about 8 bucks or something at Harbor Freight. They can really eliminate the guesswork from diagnostics. I think my concern about valve noise for years was misplaced. Our injectors make an inordinate amount of racket.
Old 09-01-2006, 07:00 PM
MMA_Alex's Avatar
yeah thats what im thinking ill do sometime early next week. Im still in the process of finishing my orientation week so I haven't had any time to drive the truck aside from moving it every 48 hours so i dont get a ticket
Old 09-01-2006, 07:10 PM
listen to the injectors, mine are noisy buggers, thought i had a valve tap too, till i got my stetho out.
Old 02-22-2007, 05:19 PM
95RunnerSR5's Avatar
sorry to revive an old thread but...i have this same tapping sound comming from the driver's side of my engine. its a newly remanufactered engine with around 15K miles on it. I already unplugged the #2 and #6 cylinder injectors one at a time to see if it was the injectors. no change. i didnt have time to get to the #4 but do you think this could be it or am i plagued with another bad 3.0?
Old 02-22-2007, 06:16 PM
pruney81's Avatar
I've got a 3.0 with 158k miles on it and it taps really bad from the drivers side too. I'm pretty sure it's the valves since it sounds metallic. Is yours a metallic rapping sound? I'm just gonna run it till it blows then sell it for parts and buy a new vehicle. I'm never going to own another 3.0 again.
Old 02-22-2007, 08:08 PM
not sure...i'll record a video tommorow so you guys can hear it
_Nicco_
09-21-2015 03:06 PM
Obmi
09-16-2015 02:13 PM
LotOMiles
09-14-2015 11:45 PM
Corvoid
09-14-2015 10:10 AM
idadan208
09-07-2015 09:06 AM
Quick Reply: Valve Tap
