Vacuum Leak Problem Areas 22re
Old 09-09-2010, 06:39 PM
BajaRunner's Avatar
I've replaced all my vacuum hoses, and intake plenum gasket. I've replaced the TB gasket, also have made sure I don't have any leaks in the intake hose (Mine is aluminum tube). I've replaced my PCV, and PCV grommet.
I've used a propane torch, like I usually do for leaks, as well as carb cleaner and water.
I still feel that I may have a vacuum leak because it runs good in open loop and bad in closed loop. The open loop runs richer and overshadows my vacuum/lean mixture.
Can the fuel pressure regulator itself cause a vacuum leak if bad? What other things do I need to look for?
Any help would be great. Thanks.
And nice new "smiley".... :wabbit2:
Old 09-09-2010, 06:41 PM
thralldad's Avatar
Brake booster?
Old 09-09-2010, 07:09 PM
BajaRunner's Avatar
Good call, never checked that one
Old 09-10-2010, 05:02 AM
thralldad's Avatar
icentropy
09-16-2020 02:47 PM
steve miller
10-10-2015 01:40 AM
Avenged
07-09-2015 07:55 AM
bryan34w
07-06-2015 05:53 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Vacuum Leak Problem Areas 22re
