V6 calipers and MC swap
Old 08-07-2013, 04:51 AM
Yamiryder's Avatar
I want to put V6 rotors, calipers, master cylinder and maybe brake booster (if it fits) on my 92 22re pickup. From what I've read, basically everything should bolt up, minus some trimming on the dust shield on the rotors. Is this right? I have a 95 4Runner with the 3vz that I have for parts that I'm taking everything off of. Just looking for some feedback from those that have done this. Thanks.
Old 08-07-2013, 05:13 AM
RustBucket's Avatar
It's a good plan and it will work. Definitely get the dual-diaphragm brake booster.
Old 08-07-2013, 05:22 AM
Yamiryder's Avatar
Okay thanks! The Runner has the dual diaphragm booster right?
Old 08-07-2013, 06:43 AM
RustBucket's Avatar
Probably. Just compare it to your current one. You can also google a bit and you'll quickly see the difference.
You may want to check if you need a new brake line as well, in case the MC position it too far for the stock ones to reach.
Old 08-07-2013, 08:22 AM
Yamiryder's Avatar
Sounds good. I think the lines on the 4Runner are still good so I could even use them
garagespace
10-11-2015 10:59 AM
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
ty1er
08-01-2015 11:53 PM
Quick Reply: V6 calipers and MC swap
