u bolt flip kit shock questions
Old 01-05-2011, 06:13 AM
Stuwy123's Avatar
There's about +5" difference between the stock shock location and mounted to the top of the U-Bolt flip plate.
They work.
Yes, the droop is ridiculous.
I'll see if I can lift the back end high enough and snap some pics.
Old 01-05-2011, 06:24 AM
yotarob2005's Avatar
Do you have them mounted strait up and down or angled in towards center? I would like to see your pics.
Old 01-05-2011, 06:37 AM
richf's Avatar
I like the sky off road kit. Because of the angle would you need to get long shocks? I have 10" now.
Old 01-05-2011, 06:56 AM
The rear hoop for upper shock mounts? I like that kit as well, but It would certianly require longer shocks.
Old 01-05-2011, 07:04 AM
  #25
richf's Avatar
Ya this one http://www.sky-manufacturing.com/new...uct.php?id=131
You don't think 14" would be required do you? I have maybe 3-4 in suspension.
Old 01-05-2011, 07:10 AM
  #26
The best way to determine what lenght of shock you need is to jack up one side untill the spring are totally flexed out and measure. You shock should not be the limiting factor in either compression or extension.
  #27
RBX
RBX's Avatar
^^^ been thinking about the same thing. I was just going to take a piece of 2" square tube and put a few nuts on it to give me some different options. And now looking at the hoop design i don't see why i couldn't just slice and weld a square tube hoop, i figure if i have to weld in a shock hoop anyhow, why not put a few more options in...just thinking outloud.
bigjstang
08-25-2021 12:41 AM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
DrZero
18
07-24-2015 11:31 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: u bolt flip kit shock questions
