Turbo 4runner 5 spped swap
Old 05-16-2008, 01:48 PM
SpecialScottie's Avatar
Hey everyone. I have a 87 turbo 4runner auto of course.
Im looking into doing a 5 speed swap. From the research ive done is it true that the only transmission that will fit it is the r151?
Is that the transmission off the 3.0 v6?
Thanks all
Old 05-16-2008, 01:54 PM
4Crawler's Avatar
R151 = the turbo 5-speed, R150 = V6 5 speed.
Major differences are the 151 has the bell housing that bolts to a 22R block and the output that bolts to a gear driven t-case. The R150 bellhousing mates up to the V6 block and the t-case is set up for a chain driven case. A W56 transmission would also bolt up, not quite as strong as the R151 but more common:
http://www.marlincrawler.com/htm/tra...ansmission.htm
Old 05-16-2008, 04:08 PM
So if i found a 4runner or pickup with the w56 I would be able to make the swap without any problems?
No I need any wiring off the donor vehicle?
Old 05-16-2008, 04:10 PM
4Crawler's Avatar
Should swap over, would need the transmission and transfer case (R151F or W56 - no difference). May need the connector and wiring for the 4WD switch in the t-case and the reverse switch in the transmission.
Old 05-16-2008, 04:11 PM
Awsome Im gonna do it.
Thanks 4crawler
Old 05-19-2008, 02:05 PM
jbone's Avatar
From what Ive read you MAY also need to find another ECU. (not sure though). I would love to a 5 speed swap in my rte! But it will have to wait
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Turbo 4runner 5 spped swap
