Truck wouldn't turn over
Old 04-16-2007, 04:36 AM
ken.vs.ryu's Avatar
The truck was sitting out in the heavy NJ rains and it wouldn't turn over. I had to crank the key for about 30 sec or more a couple of times before it finally started. After that it would get bogged down if I was heavy on the throttle.
The bogging down has happened once before but it settles down after the engine is warm.
What should I check about her not turning over? bogging down?
Thanks and stay dry.
Old 04-16-2007, 05:44 AM
NaeSLaS's Avatar
water in the distributor? water in the air filter?
Old 04-18-2007, 03:49 AM
"pete f passed away quietly in his sleep on July 13, 2008
pete f's Avatar
My engine get wet once in a while .I keep wire dri or wd-40 in cab. If it does not start right off the bat I soak wires ,coil and distributor with wd and it usually starts. If it get worst change wires and distributor cap.
GreenLion
06-07-2021 10:49 AM
Spicer
06-10-2020 08:39 PM
Aleeex_u
06-05-2016 06:52 PM
rbravo1
06-29-2015 01:34 PM
Quick Reply: Truck wouldn't turn over
