truck won't crank over
Old 07-21-2011, 04:02 AM
highway's Avatar
Question truck won't crank over
my truck has been sitting for about a week and I went out to start it and it does not crank. I can hear clicking under the hood like a solenoid but doesn't crank. The battery is fully charged, do these 89 22-re's have a solenoid switch ?
Old 07-21-2011, 10:25 AM
BMcEL's Avatar
The search button is your friend. I'll get you started...haha no pun intended. http://personal.utulsa.edu/~nathan-b.../2starterr.pdf If the relay checks out, try giving the starter a whack while turning the key.
Old 07-21-2011, 10:39 AM
snobdds's Avatar
I bet you just have a dead battery. How do you know your battery is fully charged?
Old 07-21-2011, 02:36 PM
highway's Avatar
checked it out with voltmeter
Old 07-21-2011, 06:14 PM
Bassmastry101's Avatar
Try taking the battery up to a parts store to get it checked out, just to rule it out first. I've had a lot of bad batteries show a full charge, but put a load on it and nothing.
Old 07-21-2011, 06:17 PM
AMSevo8man's Avatar
Yeah the battery may be fully charged, but it could have bad or dead cell. Or maybe the CCA is really low.
Old 07-21-2011, 08:33 PM
yeehaw1's Avatar
is the starter goin out? loose or coroded battery terminals? if it's a starter prob. try turning the key between the run and start posistions 4 or 5 times really fast. that's all i can think of if it's not turning over...
Old 07-21-2011, 08:47 PM
fork's Avatar
i had to charge a battery last week to get one of my 4runners to start despite the voltage being pretty good. voltage is not a reliable way to check the state of a battery's charge at all. try charging it first and see if that fixes the problem. also these particular starters are prone to needing a moderate whack to remind them to work
Old 07-24-2011, 10:58 AM
highway's Avatar
finally got a chance to check it out. was gonna check ou the terminals 1st but decided i would try to start it and it fired right up 1st turn of the key. BTW terminals looked goo but cleaned then anyways.
zd92655
03-06-2022 12:58 PM
Ichneumon
09-27-2015 04:21 PM
rbravo1
06-29-2015 01:34 PM
slider417
06-22-2015 10:18 AM
Quick Reply: truck won't crank over
