Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||||
Personal
Sales Rating: (0)
truck makes a clunking noise turning right.
__________________
Quote:
Quote:
1993 yota pickup. 3 slow, 4.56 gears 5 speed. plumbing isr. autopal h4 conversion, ebay hid's, 12 inch infinity sub. 3 inch body lift with 33" a/t with 15x10 eagle alloys Last edited by gary96360; 04-02-2009 at 09:23 PM. |
#2 (permalink) |
Licensed Lunatic
Personal
Sales Rating: (0)
Staff
two words
steering stops search and read up
__________________
Read them. Follow them. Live by them. ![]() just call me Travis
#3 (permalink) |
Personal
Sales Rating: (0)
I'd have someone turn the wheel for you & you peek under & see whats clunkin'..
Might be your pitman arm? Mike |
#4 (permalink) | ||
Personal
Sales Rating: (0)
[OP]
i dont think its the pitman arm cuz it only clunks turnign right, even when i turn onto another street, so thats not a sharp turn of the wheel so it cant be steering stops. in the parking lots then yes its steering stops, but the thing that worries me is that it clunks while im on the road.
__________________
Quote:
Quote:
1993 yota pickup. 3 slow, 4.56 gears 5 speed. plumbing isr. autopal h4 conversion, ebay hid's, 12 inch infinity sub. 3 inch body lift with 33" a/t with 15x10 eagle alloys Last edited by gary96360; 04-02-2009 at 09:38 PM. |
#5 (permalink) |
Personal
Sales Rating: (0)
Grease up steering stops front and back of your IFS and if it's still there you have other issues.
__________________
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front bumper-custom 6 leaf rear 01' 4Runner SR5 4WD 5VZFE all stock 3RD Gen 4Runner FAQ in progress |
#6 (permalink) | ||
Personal
Sales Rating: (0)
[OP]
its not the steering stops, i see the rubber covers on them, i dont think i turn sharp enough to touch steering stops while driving on the road
__________________
Quote:
Quote:
1993 yota pickup. 3 slow, 4.56 gears 5 speed. plumbing isr. autopal h4 conversion, ebay hid's, 12 inch infinity sub. 3 inch body lift with 33" a/t with 15x10 eagle alloys |
#7 (permalink) |
Personal
Sales Rating: (0)
Balljoint/wheel bearing play?
Abnormal tire wear? Play in CV joint?
__________________
#8 (permalink) |
Personal
Sales Rating: (0)
Gary96360...
I would check the ball joints & wheel bearings. Jack one wheel in the air just a few inches, (chuck the rear wheels & use jack stands please)! grab the wheel with one hand on top pushing and one hand at the bottom pulling repeatedly. check for play, look at the upper & lower ball joints. You can check the inner & outer tie rods too. grab the sides of the wheel & do the same thing. see if any steering parts are worn. Repeat at the otherside. i hope this helps! Mike Last edited by KONASTAR; 04-02-2009 at 11:15 PM. |
#9 (permalink) |
Personal
Sales Rating: (0)
Mine does this sometimes when im in 4wheeldrive, but only when im in reverse!!
__________________
1998 4runner sr5, 31' mastercraft a/t, clear corner and bumper lights http://www.youtube.com/watch?v=58ZVVFqhGws this is bad A |
#10 (permalink) |
Personal
Sales Rating: (0)
if, while you're turning, there is also any vertical movement (read: bumps) it might be the sway bar. i had that same issue, one side of the sway bar had broken loose and was grinding. i couldn't even see it when someone else was driving and had to take eveything apart to realize what it was.
__________________
1990 4Runner SR5 5-Spd 3.0 V6 |
#11 (permalink) |
Personal
Sales Rating: (0)
My steering stops had the plastic caps on them, visually, but still made a noise at full lock.
They wear out in the center. The cap is still there, but the middle is worn through and it is metal on metal. Check that first, easy, cheap fix. Mike |
#12 (permalink) | |
Personal
Sales Rating: (0)
Quote:
__________________
1994 Pickup 22re 5spd M/T 2WD, 188,888 miles -rebuilt front end (totaled to driving in 2 months) -custom spectre intake Toyota Pickup Repair Manual :) My Crash Repair re-Build thread |
#13 (permalink) |
Personal
Sales Rating: (0)
my truck makes a noise when i'm turning sharp in a parking lot, or when doing a u-turn. i thought it was the tie rod ends, but who knows, all the suspension on my truck is stock aside from the shocks. i guess i'll find out what it is when it breaks
__________________
'92 Pickup Ext. Cab 22re 5spd 4x4 31/9.5 TSL Radials Rattlecan'd Olive Drab DD/WW! |
#14 (permalink) | |
Personal
Sales Rating: (0)
Quote:
grease the steering stops.. It sounds deadly when they are dry! *CRUNCHYSCREEEEECH*
__________________
91 3.0 4x4 pickup - has a few mods 91 ls400 VIP on the cheap http://www.cardomain.com/ride/2572486 |
#15 (permalink) | |
Personal
Sales Rating: (0)
Quote:
passenger - "what the hell was that!?!" me - "i dunno?" passenger - "....huh, you might want to check that out" me - "nah"
__________________
#16 (permalink) | |||
Personal
Sales Rating: (0)
[OP]
Quote:
__________________
Quote:
#17 (permalink) |
Personal
Sales Rating: (0)
Remove the sway bar! The trucks don't need it. Makes for a much smoother ride!
__________________
#18 (permalink) | |
Licensed Lunatic
Personal
Sales Rating: (0)
Staff
Quote:
just too much body roll for my liking... even with the t-bars torqued a little...
__________________
#19 (permalink) |
Personal
Sales Rating: (0)
you'd be surprised how much the sway bar helps in a crosswind or when a semi passes by in the oncoming lane at 65 mph.
__________________
Proud member of Yotatech's 12000+ post club. *** STOLEN TRUCK ALERT *** *** Still active May, 2013 *** CX500TC motorcycle EFI upgrade still in progress.
#20 (permalink) | ||
Personal
Sales Rating: (0)
[OP]
i removed a sway bar on a fullsize and it leaned much as the yota with a sway bar. ill take it off to see if that caused the problem.
__________________
Quote:
| Tags |
| 4runner, clunk, clunking, jeep, left, makes, making, noise, reverse, sharp, slow, sound, truck, turn, turning, wheel |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| truck makes a weird ticking noise underneath | gary96360 | 86-95 Trucks & 4Runners | 37 | 12-21-2009 12:30 PM |
| Clunking noise | BMC | 86-95 Trucks & 4Runners | 12 | 08-25-2008 10:26 PM |
| Clunking noise | wormhole | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-08-2008 10:10 PM |
| Intermitent clunking noise when turning . | pfbmgd | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-20-2007 09:56 AM |
| Lound Clunking noise under truck when driving????? | desertyodaboy | 86-95 Trucks & 4Runners | 8 | 11-17-2007 08:59 PM |
