transmisson problems
Old 10-13-2007, 10:19 PM
Elton's Avatar
its not my truck but my mom's 92 it was doing fine was a little hard to get in reverse and now when u push the clutch in to start it theres nothing there it just jumps around in gear now im thinking it maybe the linkage ? anyone got any ideas
Old 10-14-2007, 04:02 AM
TORTIS's Avatar
check the shifter seat and bushing. i think it applies to that trans. they break down after time... marlin sells them.
Old 10-14-2007, 07:09 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Do the other gears work?
Old 10-14-2007, 07:26 AM
amgraham's Avatar
Do you mean it cranks over and the truck moves around or it doesn't crank at all? If it's the former have someone pump the clutch while you watch the clutch fork on the tranny and see if it's moving enough. If not, check the clutch fluid and if it's low fill it up and bleed it, also check the freeplay on the pedal. If it's the latter check the safety switch on the clutch pedal (it should still start if you use the clutch cancel switch).
Old 10-14-2007, 08:29 AM
n4ynu1010's Avatar
I always bypass clutch safety switches , I am smarter than the switch..........I think hehe.........previous post is good ..........Shift rod socket and shifter end bushing if it is sloppy and won't go into a gear completely , if you just can't get it in gear (grinding) then clutch/Hydraulic problem .
Last edited by n4ynu1010; 10-14-2007 at 08:30 AM. Reason: Manual Transmission Problem
Old 10-14-2007, 11:54 AM
Elton's Avatar
what mean if you try and start it in gear with the clutch in it just around the clutch pedal still has a little feel to it but you cant shift it into any gear you have to power shift it and shut it off when at a stop
Old 10-14-2007, 12:08 PM
n4ynu1010's Avatar
Clutch
Sounds like Hydraulic Clutch isn't depressing clutch arm to me , check your Hydraulic Clutch fluid and if it is low fill it and then from what you are saying it needs to be bled also or possibly MC or Clutch Slave Cyl. bad .
How old is your clutch by the way ?
If your hydraulic clutch is working then pedal should be working normal unless you have a bad clutch problem .
Look at Hydraulic Clutch MC & Slave Cyl first , verify all is good there and work from there
Old 10-14-2007, 12:56 PM
Elton's Avatar
ehh 200k + miles guessing its something to do with the slave cly
Old 10-14-2007, 09:48 PM
Elton's Avatar
i drove it today and everything felt ok ??? it started in gear just fine shifted good ???
Old 10-15-2007, 07:52 AM
n4ynu1010's Avatar
Clutch
You mean the Yota Fairy fixed it ??????
Old 10-15-2007, 08:14 AM
Elton's Avatar
it must of will see if it act's up again i will let you know
Old 10-15-2007, 09:11 AM
n4ynu1010's Avatar
Clutch Problem
Maybe you had a stick wedged in your clutch arm assy or something , I wish mine would fix itself like that
Old 10-15-2007, 03:00 PM
dlbrunner's Avatar
If the shifter thumps out of gear when you let the clutch out starting in 1st gear. the likely candidate is a bad syncro.
I have this problem, the marlin shifter seat made no difference, but my original shifter seat was fine.
The problem got progressively worse after switching to synthetic.
Time for a tranny replacement/repair
Old 10-15-2007, 03:30 PM
n4ynu1010's Avatar
Mine got better with synthetic Gear Oil , virtually never happens anymore but I beleive the guys had such a thick(High Vis) oil in it that it would not stay properly lubricated I believe because after synthetic it went away
Old 10-16-2007, 04:36 PM
Elton's Avatar
its died now it is stuck in neutral and wont go into anygear plan on replacing the salve cyl got any tips ?
Old 10-16-2007, 05:10 PM
n4ynu1010's Avatar
Have someone work the clutch and see if the MC/slave is even working first , if the MC and slave are working then look at the clutch and make sure its good , if it were bad the usual way it would have been slippping (if throw out bearing went bad you would generally hear that ) .
It may be your Tranny but lets hope not
Old 10-16-2007, 05:27 PM
amgraham's Avatar
Did you check all the crap we suggested the first time you asked?
Old 10-16-2007, 07:36 PM
n4ynu1010's Avatar
Dejavue'
HA 5 character minimum ...........I showed you !
Old 10-19-2007, 04:16 PM
Elton's Avatar
ok changed the slave cyl got one at napa for $18 dollars seems good now
Old 10-19-2007, 04:24 PM
n4ynu1010's Avatar
Clutch Master Cylinder/Slave Cylinder
Cool , thats a cheap fix , was it leaking ?
Quick Reply: transmisson problems
