Transmission oil cooler system
Old 01-20-2015, 07:28 PM
Shagool22's Avatar
Doing a 5 speed transmission swap (w56) on my 1987 4Runner. Everything's ready to go and I'm ready to put tranny in. Now that the automatic is out I can pull out and no longer need the transmission oil cooler system? Am I going to need to plug where the lines ran to the radiator?
Old 01-21-2015, 07:43 PM
hh65flyer's Avatar
Once all the fluid drains out, just cap off the ports on the rad...
I'm interested in hearing about your swap. Did you get an entire parts rig or just the parts needed? I'm considering doing this same thing to my 89 with a bad (auto) trans but trying to figure out which vehicles are compatible is difficult. 89 has the cable driven speedo so not sure what all would need to be done if my donar is from a later year. Good luck!
Old 01-22-2015, 09:40 AM
Shagool22's Avatar
I did get a donor vehicle. But that was for the 22re engine core to rebuild (mine threw a rod through the block awhile back..) so while engine is out I decided to do a tranny swap. I picked up a w56 out of a 92.. It was electronic speedo and my truck is mechanical speedo drivin.. Was able to pull the electro speedo out of tcase and I found a mechanical sending unit at my local wrecking yard.
You really do not need a parts rig. The hardest part for you would probably be finding the pedal assembly. Other than that the rest is easy and relatively cheap. I bought everything brand new except pedal assembly and tranny.
Master cylinder-13$
Slave cylinder-4$
Clutch lines-5$
Pedal assembly-30$
Clutch kit-80$
I think that's everything.. And then of course finding a transmission. Look for w56 that came out of rig older than 92. 92 is when they started electronic speedos. Hope this helps you flyer!!
Old 01-22-2015, 10:43 AM
hh65flyer's Avatar
Thanks for the reply. I'm hearing I need wiring harness', ECU, etc. Also prob driveshaft lengths different. My situation different than yours though with a V6 and auto...
Thanks for the tip on the speedo!
Old 01-22-2015, 12:13 PM
Shagool22's Avatar
I know for 22re I don't need to change ecu or harness (will have to do some splicing to get reverse and 4x4 light to work) and idk why it would be any different for v6! You are correct about drivelines tho. I forgot to mention that. You're gonna want to look for an r150 or r151f transmission. I'd go with the 151.. I do not know if the speedo sending units are universal like the w56 so it'd be best to be sure to ask seller if it's cable driven
Old 02-14-2015, 08:22 PM
tonetone's Avatar
where did you find clutch lines for 5 bucks? ive got everything at this point except the lines.
what size did you use?
Old 02-15-2015, 07:09 AM
Shagool22's Avatar
Actually for the hard line I is the only piece I took out of donor vehicle. That would be your best bet because it's already be bent and length would be right. Also, you could snag the extra brackets which would help a lot. The soft line I bought new for 12.99.
But if you need me to I can measure gauge and length of my hardline. Let me know
Old 02-15-2015, 08:17 AM
tonetone's Avatar
if it isn't too much hassle that'd be great. I was considering just doing braided from a local hyd shop but that would be kinda pricey
smthwsn357
12-04-2023 02:08 AM
mskalmus
05-28-2017 07:51 AM
Poncho0206
07-10-2015 06:21 PM
Coreyr384
07-10-2015 11:13 AM
Snort
07-09-2015 03:58 PM
Quick Reply: Transmission oil cooler system
