Transmission cooler mounted behind grill (pics)
#41
Originally Posted by snap-on
I did the same thing... T fitting in the rubber line comming FROM the tranny (before it hits the cooler) NOTE: youll need to ground your fitting for the sender to work right, i soldered a wire to the brass fitting i used. I plumbed my cooler after the radator for addtional temp drop.
I used Autometer Ultra-lite gauges. VERY nice gauges.
Ill post a pic of my setup.
#42
Yep, just called Isspro and got an answer from tech support in 30 seconds, 2 wires on their sender and one is ground so no need for another ground on the brass fittings.
#44
Mine has the wire going from the sender to the gauge and then from the gauge, one to power and one to ground. Do I still need to ground the fitting?
If so, here is a pic of my sender, can I just add the ground to the top of the sender, or does it need to be the actual t-fitting?
Thanks,
Chris
Thanks,
Chris
#45
thats the exact style sender i have on mine
before i redid my setup (after my engine rebuild) i just had a large aligator clip clipped on the hex portion of the sender.
For a more permant version i soldered a wire to the brass T houseing i have which then grounds through the threads.
remembe tradationally that sender would be bolted into a metal block or pan or something that it would get ground from.
I screwed that sender directly into the block coolant drain plug on the pass side for my water temp. 1 wire only required for that install.
#46
Well, bad news for me. I am having over heating issues. A caveat -- my situation may very well not be typical for anyone wanting to mount it in this location, but I want to post up the results from my experience, anyways.
I took the Epic Mobile for the first extended drive (just around town in traffic) since the install. I am having other engine problems, and the over heating has been chronic with my vehicle. The temps in my engine bay from the headers are just off the chart, and the little bit of air flow restriction to the radiator that this mounting location creates may not be the source of the problem, but it certainly isn't helping. So -- I'm going to relocate it and mount an additional electric fan in that space instead.
Should be good fun.
Ed
Should be good fun.
Ed
#47
I saw one of those coolers with the attached fan in the new performance products catalog. You could always use one of those and attach the cooler wherever you want, and have the room to put that fan in front of your radiator. Good luck, I hope you get it figured out
Chris
#48
Originally Posted by slosurfer
I saw one of those coolers with the attached fan in the new performance products catalog. You could always use one of those and attach the cooler wherever you want...
Chris
Chris
#49
Well, I finally got my tranny temp gauge installed. Pics later today. Does anyone know what the operating temp is supposed to be for these trannys?
#50
#51
I just mounted a new Hayden trans cooler...my old one would not fit after my axle swap...it was behind my IFS skidplate
I want a trans temp guage and was thinking about running this Perma-cool setup..also has a spin on filter, and for $80.00 seems like a good setup
http://store.summitracing.com/egnsea...5&autoview=sku
#52
How did you mount your gauge?
I mounted it on the shift console with a universal $20 mount from Pepboys. When it gets cooler in 2 months, I will install the tranny cooler. Right now it slowly works its way up and past 180 degrees driving around town....on the highway at 75mph it stays at 170. The precision is un-matchable....minor increments are every 2.5 degrees on the faceplate.
#53
That's basically where mine is too.
My temp fluctuates from about 180 at freeway speeds up to 220 on steep grades or bumper to bumper traffic on hot days. I can easily get it up to and probably past 250 if I tried. I've learned how to keep it cool by turning off the OD on steep grades. When you turn off the OD I think the torque converter locks up so it cools down pretty quick.
My tranny getting pretty old so it's probably not normal.
#54
Originally Posted by ZUK
mt.goat, thanks for the chart. I think I will make a small copy of that to keep in my glovebox. Everyone else thanks for the replies and I will post up once I get to drive around for awhile. thanks,
Chris
#55
#56
Woops, didn't see your reply zuk.
Yeah, I do think something is wrong with the tranny since the engine nor tranny used to overheat when it was new. Over the years the engine has been starting to overheat on extreme hot days on long steep grades and the tranny will do the same sometimes too. The radiator was replaced a few years back as a possible remedy and it didn't seem to help. I have an auxilliary tranny cooler too.
terminator
07-27-2015 07:13 PM
jon.r
07-11-2015 03:34 PM
