Transmission
Old 08-01-2007, 04:05 AM
martin2774's Avatar
Transmission
Hi All
I have a 92 T4R 4WD 3.0 V6 Auto.
It seems to be taking a lot longer for the transmission to warm up (ten minutes longer) and shift to the higher gears. Even though the outside temp stays 75-92.
Could the engine temp sensor be causing this?
I have been having cold start problems for a few months.
But the transmission problem just started this week.
It had a atf drain and fill about 6 weeks ago.
Old 08-01-2007, 05:48 AM
chimmike's Avatar
engine temp sensor likely has little to do with this in a car with basically an archaic computer management system.
was your drain/fill just a pan drop or was it a full flush?
Old 08-01-2007, 06:34 AM
OSU4Runner's Avatar
Check the fluid again....who did your drain and fill?
Old 08-01-2007, 07:01 AM
thefallman's Avatar
have the same problem with my A340H (same transmission you have) behind my 3.4
fluids fine. but it takes 2-5 min for the tranny to shift up. until then you drive wrapped out. im thinking its a solenoid issue but im not sure my tranny has 300+k on it
Old 08-01-2007, 07:38 AM
martin2774's Avatar
Atf was just a drain and fill.
It was working fine with the normal delay waiting for the temp to come up.
This week it takes much longer.
Old 08-26-2007, 05:30 PM
thefallman's Avatar
actually just figured this out its a malfunctioning No. 1 speed sensor at least for me.
TheBFA
02-15-2020 06:55 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
briholt
09-20-2015 10:26 PM
Quick Reply: Transmission
