Toyota Long Travel
Old 09-08-2009, 12:04 PM
  #61
BlazeN8's Avatar
Originally Posted by yoterr
yeah i allready have 35" tires and another 3" on top of my 7" of lift is kinda in the wrong direction that i wanna go with my truck but yeah camo i know what ur talking about hehe just not my cup o tee anymore i like the climbing unclimbable stuff now..and ill get a pic of the bracket lift that i have and the tabs that got cut off so you guys can see prolly tmr cuz i think ill be working on it, and blaze its gotta be the coolest idea for a lift ive seen in a while, most of the parts your braking are going to be stock parts that you can get out of a junkyard, friggin awesome!!! and if you could get more pics of the lift and how it cycles and stuff that would be pretty cool, cuz as you said we cant see the whole thing...
Yoter- I am familar with the tabs you need to cut when installing a drop bracket kit. Its at the front diff crossmember? It could be a tricky welding job to fix right, and grinding it flush inside the pocket not much fun. Are all 4 holes in the tab section gone or just the ones interfereing with the diff cover mount?
Old 09-08-2009, 12:06 PM
  #62
BlazeN8's Avatar
Originally Posted by tc
Um - they have junkyards on the trail where you go 'wheeling? Anything here breaks and you're stuck on the trail. Breaks at speed and you're pretty much dead.
I'm encouraged that the bolts are bigger than stock, but let's say I'm still skeptical.
TC- Don't be a hater, of course there are no junk yards on the trail. Carry spare parts, my point is if something breaks its not impossible or exorbitantly expensive to replace. If something fails at high speed your dead- yep! So are you if you fall asleep at the wheel.
Old 09-08-2009, 12:19 PM
  #63
BlazeN8's Avatar
I am leaving for Tahoe tomorrow for the Marlin Crawler Round-up #8 at Rubicon Springs. I wont be back till late next week and won't be checking internet stuff till I get back. I'll try to get some photos of the kit doiing its thing on the trail and post them when I get back.
Old 09-08-2009, 12:33 PM
  #64
camo31_10.50's Avatar
ooooo yes pics would be verrry nice of the kit in action..
full stuff and full droop would be nice...
for me..
i'd just put it on my truck stock..no bracket lift..(that idea was just a "what if")
so what size of tires do you normally run with this setup??
33x10.50's seem like they'd be the best setup..
maybe some 285/75's..
i doubt 33x12.50's would fit..since it widens the front end by like what? 5-6" total
Old 09-08-2009, 12:43 PM
  #65
yoterr's Avatar
with the right offset why wouldent it work?
Old 09-08-2009, 12:46 PM
  #66
yea if maybe you had like 4.5" backspacing or more..maybe 4.75 it MIGHT work if you pound on the fenders a little..
but i figured out..the wider or farther your tire sticks out..the more rubbing you'll have when you turn..
so even if you took a 31x10.50 on a 15.8 rim with 3.75 backspacing..its going to rub when turned and compressed..but it probably wouldnt rub on the highway..unless you were turning into a nasty driveway like mine..lol
Old 09-08-2009, 07:28 PM
  #67
SKULLYOTA's Avatar
neato burrito! glad i swung by to check on YT after so many months. if you post pics blazeN8, i am interested in how the LCA is contructed. I do though like your ideas with the dual shock mounting, allowing one to use larger shocks or multiple shocks without worrying about interference with axleshafts or the teeny opening in the UCA.
Old 09-08-2009, 07:36 PM
  #68
BigBluePile's Avatar
Very interesting, pics would definately be nice.
Old 09-09-2009, 12:01 AM
  #69
4x4DemonWithin's Avatar
so far from this thread ive gathered if this kit is legit it is the easiest and cheapest long travel kit around.......easiest as in i thought i heard some one say it is completely bolt on??
is there more than one kit or is it a kit that has evolved?
if there is more than one im looking for the simplest set up nothing special like dual shocks or anything just the cheapest kit that will give me lift and some more wheel travel.
I am also assuming that i dont have to do any thing special to keep my 4wd working too.
my selling points are mentioned above + if/when i break something i wont have to order it i just need to hit the scrap yard....wait all the local yards dont hardly have any yotas in them....there all out still on the trail or in some ones garage being modded!
if above is all true, sign me up for a kit!
Old 09-09-2009, 02:53 AM
  #70
BlazeN8's Avatar
for me..
I have tried a bunch of tire and rim combinations, so much so my tire guy at Tucker Tire thinks I am crazy. I think the stock SR-5 aluminum rims that came on the 80's and 90's rigs are the best. See home page photo of the blazeland website. These rims are a 15x7 with a 4.5" backspace. The deep backspace and 7" width keeps the track width narrower. For a tire I like the 32x11.50 or 33x12.50 (a 1" body lift is needed for the 33" or you can hammer the firewall seam flat and run fiberglass fenders). Mfg BFG says to mount either tire on a 8.5-10" wide rim but I have been happy with it on a 7" Mfg BFg says 33x10.50 on 7" rim is recommended. I like this size too (and no flattening firewall seam or fiberglass needed) The wider sizes give more flotation. A 285/75/R16 is a good size too (sim size as 33x12.50 just a tad narrower) If you are wanting to run a 4" drop bracket kit or a coil spring behind the UCA then you want a shallower backspace, a wider rim, a narrower tire..... you get the idea . Drop bracket kits have a disclaimer that says you need a 3.5" or less backspace w/ 33x12.50 tire, I also found this to be true with a combo kit configuration.
Old 09-09-2009, 03:25 AM
  #71
BlazeN8's Avatar
To keep it simple, what tire size works on a your rig before the Blazeland LT will work after the install. If it rubs now, it will rub after. The Blazeland LT, when compressed, is pretty much the same as where you started for the tire clearences. The extended (droop) reach is where you will get the extra travel. Measure your baseline before the install, install the LT, then add about 3" to the baseline height. The ride height is adjustable depending on torsion bar pre-load. If you crank in too much lift you won't have any additional doop, if you don't crank in any lift you wont have any additional compression. You want to balance it somewhere in the middle.
Old 09-09-2009, 04:00 AM
  #72
BlazeN8's Avatar
You heard correct this is a bolt on kit. If you want to add additional upgrades such as dual shocks or a coil over conversion then you will need to fabricate LCA mounting tabs and shock hoops as needed on your own.
I have made other kits over the years, but this is the production model. I found this to be the best balance for simplicity, function, and cost effectivness.
You don't need anything special to keep 4wd except longer CV axel shafts. And guess what they are easy to find and cheap. Just get the ones used for the Toyota T-100, they bolt right in. They are in auto parts stores everywhere, new or remanufactured. Or call around salvage yards and buy used. Prices range from about $50-150 each.
Old 09-09-2009, 04:31 AM
  #73
BlazeN8's Avatar
I'll be posting some action shot photos next week when I get back from the Rubicon. I will also be updating the blazeland website in the weeks to follow. That's a silly question, you wouldn't ask Superlift how they constructed one of their kits would you? Proprietary rights my friend! Yeah, the dual shocks are nice. They dissapate heat better than the single Billy's on sustained whoops but the valving is similar to the vehicle specific single shock I recommend. If your into pre-running its worth it, but for trails, street, and mild stuff not necessary and just added bling.
Old 09-09-2009, 04:41 AM
  #74
from stock how much more travel will be gained by your basic kit and no extra fab work done just your kit alone? you have stated that over all travel is 12 inches with the bump stops removed. how much more is that then stock? doesnt have to be exact just looking for an estimate gain.
and as far as i see the only way to order up a kit would be to contact you through your email right? would you be interested in putting together a all in one kit like the T-100 axls and stronger torsion bars<---i was looking to go with 35mm. so perty much i can just order from u, put my truck under the carport and lil while later drive away and go test this bad boy<---vids and pics to follow
Old 09-09-2009, 05:59 AM
  #75
SKULLYOTA's Avatar
yes i would ask anyone about their kit. safety first right? i only wondered why you used two different means to lengthen the uppers vs. the lowers.
Old 09-15-2009, 10:15 PM
  #76
deathrunner's Avatar
Cool idea. I definitely want to see more pics. budget long travel....sweet!
Old 09-15-2009, 10:20 PM
  #77
AZkid's Avatar
if i had the money i'd buy this kit, regardless of what others say.
Old 09-18-2009, 06:34 AM
  #78
BlazeN8's Avatar
Its fair to ask! I used different means to lengthen UCA vs. LCA because I was unable to build a bolt on bracket for the LCA. It would have been sweet to be able to bolt something onto the LCA because cutting and lengthening a stock one and doing a core exchange is a lot of work. I am debating selling a DIY weld up kit but am not sure it can be done without a fixture or jig to get the geometry correct for cutting or welding. Call me off line and I will disscuss it with you. (949) 903-6892
Old 09-18-2009, 07:00 AM
  #79
BlazeN8's Avatar
I measured the stock configuration a long time ago but don't remember exactly what it was. I probably have it in some notes filed away some place? Anyway, an estimate of what I recall is stock cycles about 7-8" w/o bumpstops. So, you are going to gain about 3-4" of additional travel.
I found it is easyer to offer my componants and let you guys get the additional componants on your own. This way you are in control. This gives you the opportunity to find the best pricing, save on shipping, attain the flexibility of choosing multiple manufacturers products, and modify and upgrade to suit your preferences. I can be reached at (949) 903-6892.
Old 09-18-2009, 05:12 PM
  #80
SKULLYOTA's Avatar
i get ya, i see how lengthening the stock arms would be very time consuming, and how hard it would be to make a bolt on for the lower arm.
any pics of it in action yet?
Quick Reply: Toyota Long Travel
