Total Paint job for a '88 pickup
Old 07-12-2008, 06:29 PM
g_mau18's Avatar
I was just wondering If anyone has a yota pickup and has a color change paint job on it? I want to change it from grey to dark green, just wanted to know estimates, if anyone has done it before.
Old 07-12-2008, 06:31 PM
skinnyhb's Avatar
www.rollyourcar.com
Old 07-12-2008, 06:37 PM
Myers504's Avatar
do you do it your self?
Old 07-12-2008, 06:47 PM
EWAYota's Avatar
you can squeek by doing the roll on method for under 100.00, or go buy some spray cans and go at it till your pointer finger cramps up on ya.
Old 07-12-2008, 06:50 PM
Etype R's Avatar
If you use spray cans, spend the 3 dollars for a spray can trigger.... This isn't needed so much for Duplicolor paints as they have quality nozzles. But the handle with these triggers does give you better control as well.
Old 07-12-2008, 06:51 PM
Myers504's Avatar
ha
i think i will do the roll on method
Old 07-12-2008, 07:17 PM
Etype R's Avatar
I did the roll on method over a year ago... I've had to do some body work since then, and use spray paint. The roller method takes a few days, you can rattle can it in a single day.
Old 07-12-2008, 07:44 PM
Myers504's Avatar
but do you think the rattle can will look the same
if you got pics of it hit me up
so i can see them
Old 07-12-2008, 07:56 PM
Etype R's Avatar
In this picture, some of the cab is still the orginal roller paint job, the entire bed is rattle canned.
And before rattle can touch ups...
As for which one holds up better, its hard to say. I seem to have a habbit of hitting trees, then having to do body work to keep it from rusting any more then it already has
Old 07-12-2008, 08:16 PM
Jay351's Avatar
Hey Etype. Great lookin truck! I am considering the roll on job on my truck next year.
Old 07-12-2008, 08:22 PM
Myers504's Avatar
i think i might go with the roll on stuff
idk why but i hate spray can stuff
but thanks for showing me how it looks tho
-myers504
Old 07-12-2008, 08:43 PM
EWAYota's Avatar
Etype, awesome job on the application. How much time in prep work and post paint (wet sand, buffing) did you spend?
I've seen the same results from rattle cans, it all boils down to prep work and patience.
Old 07-12-2008, 08:57 PM
Etype R's Avatar
Thanks, I ended up spending 3 days from start to finish. I took advantage of the 3 day memorial weekend last year. Most of the time is spent sanding. First I took down all the rust spots the best I could, then wet sanded the entire truck, smoothing everything out the best I could. I washed it 2 or 3 times before I was ready for paint. Then I would lay a light coat down, go inside and watch a episode of Top Gear. Hour or so later I would add another coat, repeat with a third coat before sanding it smooth again. But before the third coat could be sanded, I had to let it cure over night. Some areas were sanded down to the old paint again, so it took another 3 or 4 coats.
In the end I had orange peal on the entire truck, I don't think I thinned the paint out enough. But it looked fine from 20 feet, and I was able to buff most of it out to a decent luster. But I have had better results with a spray can. I might pick up a cheap harbor freight paint sprayer, and run the same paint through that? I've heard that works very well.
bigjstang
08-25-2021 12:41 AM
icentropy
09-16-2020 02:47 PM
Avenged
07-09-2015 07:55 AM
karbin
07-05-2015 11:37 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Total Paint job for a '88 pickup
