timing puzzle
Old Nov 21, 2007 | 02:47 AM
youngyota88's Avatar
timing puzzle
quick question.
when i set the new tps to idle
do i set base timing on the engine first then jump the terminal
do i jump the terminal then set the base timing
when will the ecu advance the timing.
are there different steps to doing this
Old Nov 21, 2007 | 06:21 AM
billmaness's Avatar
Set TPS first.
Insert jumper wire. (idle should change when doing this)
You are now in base timing mode.
Set engine idle.
Set timing.
You will not be able to do base timing if TPS is not working.
I went thru that last week.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
