| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Timing Issues?
#2 (permalink) |
the base timing is 5 degrees btdc. you did short out the eg1-t1 connector before setting the timing right?
#3 (permalink) |
Is it the same short that you use to read the engine light code? If so, then yes. This is how I did the timing on my truck:
1. Jump the diagnostic nodes. 2. Disconnect & plug vacuum lines to distributer. 3. Adjust distributer to line up the notch to 5 BTDC 4. Reconnect vacuum lines. 5. Disconnect jumper from the diagnostic box. Is this not correct? It seems like the rough, choppy acceleration would be due to improper timing, but the mark does line up with 5 BTDC. |
#4 (permalink) |
When setting my timing I didn't disconnect any vaccuum lines. Just warmed it up, jumped the terminals, and set it to 5 degrees btdc.
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s |
#5 (permalink) |
I'm supposed to jump the diagnostic terminals for the duration of the timing adjustment, correct?
#6 (permalink) |
yes. start the engine, and look at the timing, then jump the terminals, and the advance should drop.
at idle it should be like 12-13 without the jumper, and 5 with it. if it doesent drop with the jumper in then its usually gunna need a tps adjustment before doing the timing |
#7 (permalink) |
I'm getting really frustrated with the truck now. I've fooled around with the timing so much, I don't know if it's a timing issue anymore. The truck stumbles through acceleration no matter if the timing is advanced or retarded or at spec. It only stumbles when it is in gear (any gear, though not so much 1st). Any ideas?
#8 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Have you tried adjusting your TPS? If it's off, your timing will not be set correctly.
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Timing issues | mytoy | Newbie Tech Section | 13 | 07-16-2007 11:59 AM |
| timing belt issues | budro | 86-95 Trucks & 4Runners | 3 | 05-19-2007 05:12 PM |
| Timing Chain Issues | cweich | 86-95 Trucks & 4Runners | 2 | 05-03-2007 07:55 PM |
| timing issues | tampabayota | 86-95 Trucks & 4Runners | 5 | 02-12-2007 11:41 AM |
| Timing issues... | MarkH1121 | 86-95 Trucks & 4Runners | 8 | 12-05-2006 10:03 AM |
