timing chain too short
Old 05-11-2010, 05:11 PM
Rusted Rooster's Avatar
Hi everyone, Having problem getting timing chain and spocket to reach cam? replaced head gasket, after getting head back on, seems chain and sprocket dropped down a little bit...looked down and can see oil pump plunger extended out pushjig on chain... shorting it just enough so i cant reach cam.....any help here? I did twist tie the chain to spocket as said. thank you,
Old 05-11-2010, 05:12 PM
ohg yeah 1986 22r carb
Old 05-11-2010, 05:15 PM
92 TOY's Avatar
HEY.
when i did mine i pulled slowly on the passengers side of the chain steadily and the tensioner slowly went in......enough that i was able to get part of the sprocket on....i pulled the chain a little more and got more bite.....then i took a block of wood and held it over the sprocket and tapped it into place.
Old 05-11-2010, 05:17 PM
slacker's Avatar
the problem is the tensioner is "advanced" to it's max .. what i do is use a heavy screw driver threw the center of the cam gear for leaverage .. you need to lift up the gear and tighten the chain to collaps the tensioner . then it will "slip" onto the cam
Old 05-11-2010, 05:20 PM
PlanB's Avatar
If you lift firmly with a little more pressure on the left side it should depress the timing chain tensioner just enough to clear. If this doesnt work, you might need a hand. Have someone touch the top of that tensioner with a long screwdriver or something while you provide lift. dont pry
Old 05-11-2010, 05:37 PM
thank you so much guys...will try in morning...g.l.w. t
Old 05-11-2010, 05:50 PM
92 TOY's Avatar
good luck...let us know how it works out
Old 05-12-2010, 04:48 AM
THANKS again,, just ran in to post that I got chain on.... used a little bit of all your posts it worked Great answers guys,,, appreciate it!...Rusted Rooster.
Old 05-12-2010, 04:52 AM
92 TOY's Avatar
good deal man.
carry on.
Old 05-12-2010, 05:13 AM
waskillywabbit's Avatar
This is how it is supposed to work
Question. Advice. Update. Solved.
Colington
03-08-2020 09:51 AM
jon.r
07-11-2015 03:34 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: timing chain too short
