Throttle Position Sensor Reminder
Old Jan 22, 2007 | 09:43 PM
Ebin's Avatar
When setting TPS with a meter while it is on the vehicle, remember that terminals are going to be reversed from the manual (top is bottom, bottom is top). Orient the "hub" of the TPS as it is in the manual.
Old Jan 23, 2007 | 06:24 PM
design311's Avatar
Never done this, just clarifying in case I ever need to check mine...
http://www.4crawler.com/4x4/CheapTricks/TPS/tps2.gif
The top post is actually "E2" when it is still attached to the throttle body, correct? Sorry for the stupid question.
Old Jan 23, 2007 | 06:29 PM
4runnerx3's Avatar
Old Jan 23, 2007 | 10:43 PM
highway74's Avatar
I could only get mine in adjustment with continuity per the FSM, infinty didn't seem to work with the meter.
Old Jan 24, 2007 | 04:05 PM
design311's Avatar
Good post. Thanks for the heads up :bigclap:
Old Feb 14, 2007 | 09:36 PM
Ebin's Avatar
I meant the post for the 3VZE. The manual gives terminal position looking at the front with hub on right. When in actuality you will be measuring terminals from the back with the hub on the left. If this is confusing email me...maybe I can confuse you more...lol. And yes, E2 will be on top.
crammit442
7
Nov 29, 2017 12:30 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
