Is this third member information correct?
Old 07-08-2010, 09:05 PM
the_supernerd's Avatar
I want to regear my 4x2 that has an 8 inch rear end. I was reading that some 3rd gen 4Runners and Tacomas come with the same 8 inch third. If I understand correctly, all 4Runners up to '02 came with the 8 inch, and only TRD Tacomas came with an 8 inch. Does this mean I can get a third from an '02 4Runner and bolt it in my '88 4x2? Are all 8 inch thirds the same regardless of 4x4, 4x2, or year?
Old 07-08-2010, 09:30 PM
From what I have found, most 5 lug 4x2s came with the 7.5 inch, but some came with the 8 inch. Mine has the 8 inch with 3.07s As far as I know, the 4x2 8 inch came with 3.07 (4 speed), 3.42 (turbo & V6), 3.90 (1 ton) and 4.11 (some cab & chassis).
I know that mine is 8 inch, but I am wondering if it swaps with a 4x4 8 inch, mainly from the 3rd gen 4Runners so I can get a newer one with less miles.
Old 07-08-2010, 09:50 PM
PismoJoe's Avatar
Great site with identification info
http://www.off-road.com/trucks-4x4/t...ion-18588.html
PismoJoe's Avatar
This site has good comparisons for thirds, what swaps and what doesn't http://home.4x4wire.com/erik/diffs/
Old 07-08-2010, 10:28 PM
Staff
DeathCougar's Avatar
Originally Posted by razed
2wd rear to 94.5/95 (not 'tacoma' truck) shold be 7.5" except some 90+ 2wd 4runners which should be 8"
if the axle has 5 lugs for the wheels its 7.5, 6 lugs is 8
unless I'm wrong.
Wrong
Toyota made a 2WD 5 lug one ton with an 8" diff.
Most common ratio was 3.42, but I have seen others as well.
They also built the Turbo 2WD trucks with 8" diffs, and they were 5 lug as well.
Old 07-08-2010, 10:54 PM
That second link is the one where I initially got my information. It says the 3rd gen 4Runners use the same 8 inch differential with a "new and improved" housing. I am wondering if the entire third, including the housing will bolt up, or if it is just the gears that can swap.
My axle is a G662, so 8 inch, 3.07, 2 pinion without limited slip. It has a carbureted 22R and a W46 transmission. Usually carbureted trucks have a G transmission and 4x2s have a 7.5 inch diff. I have found a few other trucks on here with my same combination, and they usually cause some confusion.
The earlier dually trucks and Toyota based RVs had 8 inch differentials with dually adapter rims. These were a problem on RVs because the weight of the RV combined with the leverage of the outer dually wheel were snapping axle shafts. There was a actually a safety recall for RVs to replace the axles with full floaters. You can read about it here:
http://www.toyotamotorhome.org/class...s/Axle_FAQ.pdf
Old 07-08-2010, 11:02 PM
Staff
G662....do you have a motorhome?!
Old 07-08-2010, 11:06 PM
The truck with the axle code G662 is not a motorhome. It is a base model 4 speed pickup with 3.07 gears for economy. I brought up the motorhome because razed was talking about the dually adapters. I just parted out a motorhome that had a full floater with 4.30s on it and that is where I got some of the motorhome information.
Old 07-08-2010, 11:08 PM
Staff
I was asking because its weird that a base model truck has an 8" diff.
I would verify that is what you have before ordering a diff from somewhere.
Something else to consider is axle spline count. I am not 100% sure 2WD and 4WD use the same size and count splines
Old 07-08-2010, 11:32 PM
I always thought it was strange that 3.07s are 8 inch. I checked the axle code, the third look just like the 8 inch in my 4x4 and different than the 7.5 I have in my yard, so I am 99% sure it is 8 inch. I have also seen a few other trucks with the same axle code.
I will definitely research the spline count before I buy a new third.
Old 07-09-2010, 04:47 AM
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
My pickup is G662 as well. The 3.071 gears are slapped onto the 4spd G40 tranny setups from what I can tell, so that 4th gear can maintain highway speeds at a reasonable rpm with stock tyres. Accelerates like an old woman with a cane.
Spline count is the same as the 4wd axle shafts (lockright for 2 pinion 3rds fits my shafts), the only difference from the 2wd 8" rears seems to be the drive flanges on the axle shafts for 5-lug and brakes. Well, that and the topmost fin on the 2wd 8" 3rd sticks out more.
Old 07-09-2010, 06:06 AM
iamsuperbleeder's Avatar
how do people acquire such knowledge
Old 07-09-2010, 11:15 PM
Staff
me wondeers too. i had a hard time getting someone to tel me to take the shims off my axles to fix a vibration.
Interesting, wonder why that may have been?
89fourrunner
02-17-2016 06:52 AM
Flossy
08-05-2015 05:14 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Is this third member information correct?
