Tdc
Old 11-20-2009, 07:20 PM
Nuke's Avatar
Tdc
I'm in the middle of replacing my timing chain. I match marked all the timing pieces. When I took off everything, you will see in the pictures (notice the silver match mark) that the crankshaft keys where not at the 12 o'clock position. When I move them to the 12 o'clock position, the number 1 is at TDC. I plan on reassembly with the keys at the 12. Any reason why I shouldn't?
A little background: I replaced the chain on a whim. The driver side chain guide was broken but the tensioner seemed fine. There was enough play in the chain that I could move the crankshaft without the cam shaft moving, about 5 degrees. Thanks.
Marsheen
02-17-2016 12:29 PM
voiddweller
09-28-2015 11:21 PM
PBRaddict#1
09-22-2015 07:50 AM
Jason Webber
09-02-2015 03:30 AM
cgilley
07-25-2015 10:55 PM
Quick Reply: Tdc
