TC's 2nd Gen - Rear 4Link Swap (Buildup Thread)
Old 11-02-2009, 08:06 PM
  #141
1990IFS's Avatar
i need to rock the axle back for pinion angle.
Old 11-02-2009, 08:34 PM
  #142
peow130's Avatar
wat?
why did you bump the thread?
Old 11-03-2009, 07:31 PM
  #143
tc
tc's Avatar
Yeah, probably the only regret I have is not going to a double cardan drivesahft and pointing the pinion at the tcase. Right now, the driveshaft is below the links and kinda unprotected.
Old 11-03-2009, 08:36 PM
  #144
AxleIke's Avatar
Well, it does do nicely for ground clearance, but on mine, I have to fill up the last of the oil from the vent hole. If you ever do this, weld the fill hole shut, and put in a larger, inspection plug up higher, so you can fill. Wish I'd done that to mine.
Old 11-20-2009, 11:46 AM
  #145
Booosted Supra's Avatar
Great build up, I read the whole thing because I am looking to do something similar but I didn't see any info on whether you guys have to relocate the gas tank or not? because right now I think thats my biggest issue... trying to figure out a real clean way to move it
Old 11-20-2009, 12:46 PM
  #146
AxleIke's Avatar
TC has not had a stock tank for years ever since his stock one fell off. He's using a fuel cell mounted in the back end, fills through the back window.
Old 11-20-2009, 06:30 PM
  #147
tc
tc's Avatar
Yep
Old 02-23-2010, 07:49 AM
  #148
tc
tc's Avatar
Update:
Axle housing got bent. Replaced with a Trail Gear.
Will upload some new pix.
Old 02-23-2010, 08:13 AM
  #149
camo31_10.50's Avatar
FRIGGIN SUH-WUH-EEETTTTTT
yes this build deserves a 3 syllable 'sweet'
Old 03-23-2010, 04:45 PM
  #150
jwenz723's Avatar
Originally Posted by tc
Update:
No pictures still??
Old 03-23-2010, 07:09 PM
  #151
tc
tc's Avatar
Been busy dealing with Trail Gear's shortcomings ...
Old 03-30-2010, 08:07 PM
  #152
tc
tc's Avatar
Pix from today. Installed stock bumpstops and was testing them out ... to find they are too short to keep the tire out of the exo ...
Old 04-09-2010, 09:14 AM
  #153
stock as possible's Avatar
So you had to cut all that link mess off of your stock axel housing and reweld it to the TG one?
Old 04-09-2010, 11:19 AM
  #154
AxleIke's Avatar
Not really a mess.
Just got 4 new brackets, and lined everything up. Then welded the new brackets and truss on. As for the coil buckets and shock mounts, everything is easy with a plasma cutter.
Pretty much bolt in at that point.
Old 04-09-2010, 01:19 PM
  #155
"mess" was not the best use of my vocabulary, wasn't trying to step on any toes.
It just gives me nightmares to think about doing all those calculations and taking all those measurements and doing all that work just to have to do it all over again a year later. But I see your point that he wasnt starting from scratch the 2nd time around.
Old 04-15-2010, 09:41 AM
  #156
Lysmachia's Avatar
PITA though would have been a correct term for the whole thing.....
Old 10-29-2010, 04:15 PM
  #157
ToyotaLee's Avatar
Updates?
Old 10-31-2010, 08:19 PM
  #158
Lysmachia's Avatar
Oh Hey! I forgot about any further updates! We finally got everything buttoned up I think last April? At any rate we didn't wheel much because Troy was between Jobs. We have since then Moved to Houston (Troy has a great Job here). But there is no wheeling close (Closest is 5 hours away!) While I think we still will get to wheel some, it will be nothing like we did in Colorado.
The 4 link is still doing great. But all of that engineering we did is lost on a Truck in Houston. We might end up selling his rig at some point. We'll see... (We'll prolly sell one of our 2 rigs and at least keep one).
Old 12-01-2010, 08:48 AM
  #159
i'm sure there is some good wheeling somewhere.
heck NOONE seems to go wheeling in oklahoma, or so i thought.
then i got too lookin and found Disney (found that fast..lol) and Camp Gruber ORV park (however i can only find 4wheeler trails..??) and then theres also Little Sahara...but that's not my cup of tea
plus tons of small spots on private land around the area.
best thing to do is be on the lookout for other wheelers, even if they're high school kids...meet some, wheel, meet better people, wheel some more.
Team420
01-12-2021 04:57 PM
stav
07-07-2015 07:57 PM
marcusSRG
06-27-2015 07:13 AM
cchinny
06-25-2015 08:11 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: TC's 2nd Gen - Rear 4Link Swap (Buildup Thread)
