Tailgate shackles
Old Sep 9, 2008 | 02:48 PM
874runnersr5's Avatar
Tailgate shackles
Anyone have that problem with their tailgate shackles having excessive play so when you move your truck side to side it like makes a annoying metal clanking sound??
anyone know how to improve/fix it? i was thiking of buying a cable like how truck's have them but not sure if they'll work
Old Sep 9, 2008 | 03:01 PM
Jay351's Avatar
Mine used to do that because the PO stuffed a different bolt in one of the mounts/pivots. I got the oem bolts and was able to snug it down. Not a peep since...
p.s cables SUCK!
Old Sep 9, 2008 | 03:04 PM
abecedarian's Avatar
something else you might be able to do is get some pieces of heat shrink tubing and cut them to fit over the arms to act like a bumper so they don't rattle.
4Crawler's Avatar
Get the replacement plastic clips from Toyota they are designed to stop that rattling.
Old Sep 9, 2008 | 03:05 PM
hmm hmm, alright. Il check the bolts to see if their all the same. and yeah, il go to the stealership and buy some clips.
Old Sep 9, 2008 | 03:08 PM
corax's Avatar
mine does it all the time - from factory there were 2 little plastic clip things that kept the shackles pushed to one side so they wouldn't rattle, the clips are broken now but I was thinking of trying to improvise something - maybe glue a rubber pad on or something
Old Sep 9, 2008 | 03:11 PM
do these clips go between the two shackles? or on the bolts?
I8URSVT
Mar 2, 2021 06:23 AM
matmattmatthew
10
Feb 9, 2021 04:15 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
oldblue
Sep 28, 2015 04:07 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
