tach wire?
Old 01-17-2007, 12:13 PM
943kgt's Avatar
tach wire?
ok i installed a remote start in my 1995 toyota pickup 4wd 22re manual. i need to splice into the tach wire but am unsure of where it is located and what color it is? thanks in advance!
Old 01-17-2007, 01:08 PM
Marc's Avatar
I believe it's the IG terminal in the same connector in the engine compartment that you access when setting your timing.
Old 01-17-2007, 01:09 PM
rdlsz24's Avatar
Will going to the negative terminal on the coil work? That's where I get the signal for my aftermarket tach.
Rob
Old 01-17-2007, 01:41 PM
CLEANSR5's Avatar
Aren't tach's usually a blue wire?
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
Daneums
07-28-2015 11:57 AM
altydog
07-28-2015 10:20 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: tach wire?
