Tach reading wrong!
Old 08-14-2012, 01:57 PM
ybanshee68's Avatar
Tach reading wrong!
Well I was driving down the road this morning and I let off the gas and the tach dropped to zero. So the first thing I thought is the engine must have stalled (very quiet exhaust), but I hit the gas and the tach raised back up. Also at highway speeds I noticed the tach is higher then normal. Has anybody seen this. Is there any fix or do I need to start hunting down a cluster.
Old 08-14-2012, 03:04 PM
scope103's Avatar
Are you sure it didn't stall, and then restart with the gas pedal? Reading higher than normal could be a slipping clutch or failure of an automatic to lock-up.
So do it the easy way. Spring for a cheap tachometer http://www.autozone.com/autozone/acc...uestid=1873634 and actually measure the RPMs. Much cheaper than buying a cluster you don't need.
Old 08-14-2012, 08:18 PM
TNRabbit's Avatar
I'm betting you have an alternator going bad. Weird readings like that are usually a result of unusually low battery levels.
Old 11-14-2012, 04:26 PM
climbBC's Avatar
Did you ever figure this out? I have the same thing going on (just started up today) in my '94 Pickup (22RE).
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
altydog
07-28-2015 10:20 AM
montanatruck
07-25-2015 03:45 AM
1996Taco
07-20-2015 12:02 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Tach reading wrong!
