t-case rear output bearing
Old 02-24-2006, 07:29 PM
tntoyota22's Avatar
ok im about to try to change the rear output shaft bearing in my 87 truck. Ive never done this before and need advice frome someone that has. Im changing the bearing because i can move the drive shaft up and down about half and inch in any direction. the trnsfer case hase 7 bolt on the rear retainer plate if this helps.
Old 03-03-2006, 05:58 AM
tntoyota22's Avatar
Am i here all alone.
Old 03-03-2006, 06:47 AM
seaflea's Avatar
Have you pulled this case out of the rig yet? You will need a press to take off and replace it. You may as well plan on rebuilding the whole case while you are at it. If the bearing is as bad as you say, there will be a lot of metal floating around in there and has started to tear up other parts also.
Good luck.
Old 03-03-2006, 06:55 AM
Cebby's Avatar
Good luck.
I'd agree with this assessment. Have torn two down a little while ago, there's a lot of things to inspect in there. Fortunately for me, mine were in great shape inside.
the1998sr5
15
07-14-2020 08:35 PM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
89hilux1
07-19-2015 01:32 AM
Quick Reply: t-case rear output bearing
