Suspension lift options
Old 11-28-2007, 09:41 AM
4Crawler's Avatar
You can install ball joint spacers up from for 1.5"-2" of lift:
- http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
And for the springs in back, you can get a set of new springs from some place like JC Whitney, or OME and Downey have 2" lift springs or you could use a Rancho Soft-Ride Add-a-leaf kit with your existing springs.
Old 11-28-2007, 09:44 AM
traben27's Avatar
Listen to AxleIke. Enough said.
Old 11-28-2007, 10:10 AM
acerbis's Avatar
lca?? what is that? And axleike, sounds like good advice. My truck doesn't seem to be squatting too much. But i guess leaf springs wear out unlike the torsions?
Old 11-28-2007, 10:20 AM
JonnyBoy's Avatar
f4stunna, for what you're talking about prolly the best way to go is new OME rear leafs since you have a broken one, an add-a-leaf is worthless to you. To keep it level, you can either tighten the tension on the torsion bars(springs, but not the traditional style ya normally think of) or install ball joint spacers between the wheel hub and the upper control arm. The spacers is the route I would go, you can keep pretty close to stock ride quality with 2" lift. Then OME shocks, go with cheaper if you want, but they are excellent! Then your lift is taken care of...ball joints up front if they need to be done, just get them from a parts place and install 'em while you have the wheels off for the lift.
acerbis, lca stands for lower control arm, and all springs wear out over time, some are simply more prone...apparently stock 'yota leafs are prone, just like cheapish brand of lift leaf springs will usually sag after they've been loaded a couple times.
Old 11-28-2007, 10:31 AM
  #25
f4stunna's Avatar
so new shocks, new leaf springs and ball joint spacers, thats it?
i think im leaning that way...
Old 11-28-2007, 10:40 AM
  #26
JonnyBoy's Avatar
Yes, that takes care of lifting it.
As AxleIke said:
rear leafs $200
shocks 4x$80
bj spacers $125
And, taking care of any other loose crap up front. Even 2" of lift puts more strain on your steering components, stock parts will hold unless you're doin extreme stuff, but not worn out stock parts.
Old 11-28-2007, 10:46 AM
  #27
f4stunna's Avatar
so wheres the best place to order the OME stuff?
Old 11-28-2007, 11:06 AM
  #28
AxleIke's Avatar
TRDParts4U.com
Old 11-28-2007, 01:21 PM
  #29
acerbis's Avatar
can someone post the link for our trucks. i can't find it on there. trdparts.com
Old 11-28-2007, 01:51 PM
  #30
f4stunna's Avatar
no luck with the trdparts site....
anywhere with free shipping?
Old 11-28-2007, 02:34 PM
  #31
AxleIke's Avatar
Sorry. Here is a better link. It says for pickups, but they are the same as the first gen 4runners.
For the rear, you pick the spring set you like the best.
https://www.yotatech.com/forums/f37/...kit-ome-78776/
Old 11-28-2007, 02:50 PM
  #32
Luvmeye22re's Avatar
Good plan.... those bracket style ifs lifts used to be around 500 bucks even two years ago, Ive seen a couple of them come in at around a thousand bucks lately, and Trail gears sas kit is only a little bit more than that. If your front suspension needs work, no lift is going to help it unless you are getting a total chaos kit, but you really probably only need bushings, ball joints etc. which bracket lifts do not come with.
And a good place to order OME parts is www.cruiseroutfitters.com . I know they don't really have much listed for pickups/4runners but Kurt is a great guy and very reasonably priced. You may have to call him if you don't find what you want on his website.
Old 11-28-2007, 05:14 PM
  #33
fire5's Avatar
What all bushings should or could be changed and where is a good place to buy them?
Old 11-28-2007, 05:55 PM
  #34
AxleIke's Avatar
Normally, the only bushings that need changing are the lower control arm bushings. There are 4.
The best place to get them is the dealership. They are expensive.
Old 11-29-2007, 05:41 AM
  #35
f4stunna's Avatar
so where is the best place to get OME stuff?
i just priced up the 4 shocks and leaf springs at 4by4connection.com and its 559.56 after shipping
the ball joint spacers are 116 shipped....
so thats up to 675 for just shocks, leaf springs and ball joint spacers....
Old 11-29-2007, 05:50 AM
  #36
f4stunna's Avatar
add in OME rear bushings and u-bolts and its up to 648.48...
so a total of 775 with ball joint spacers
Old 11-29-2007, 07:23 AM
  #37
AxleIke's Avatar
Sounds good.
You can talk to phil, who's post i referenced above, who works at TRDParts4U. The reason I suggested him is often they will cut deals for YT members. Have you talked to them?
Good luck.
Old 11-29-2007, 07:31 AM
  #38
bob200587's Avatar
I got the best deal at a local 4x4 shop. You should check at one.
Old 11-29-2007, 07:33 AM
  #39
f4stunna's Avatar
Originally Posted by AxleIke
Sounds good.
Good luck.
not yet
Old 11-29-2007, 07:34 AM
  #40
f4stunna's Avatar
can anyone get OME stuff?
Quick Reply: Suspension lift options
