Suggestions...where's this leak in these pics
Old 02-06-2008, 06:01 PM
snelson's Avatar
92 3VZE Manual 4X4
Hey guys, can anyone help me determing where these leaks are coming from? I seem to have a small oil leak up on the passenger side near where the clutch enters the transmission. I replaced the HG in the summer, and at that time had an issue with the clutch where it just fell to the floor, I had to bleed the clutch to get it firm again. Should I be replacing something in that area.
I've also noticed a small leak/ooze from the rear driver shaft where it meets the diff. How does it look in the pic? Anything to be worried about here? Typical for a 15 year old truck?
Thanks guys
Steve
Old 02-06-2008, 06:31 PM
4x4YOTA's Avatar
the first one looks like your slave cylinder and the one on your axle looks like a pinion seal from what I can see but cant really say unless I actually saw it sorry
Old 02-06-2008, 06:46 PM
881stGenRunner's Avatar
are yor valve cover gaskets leaking? Check those. The rear one is called the Companion Seal, very easy to replace. However the valve cover gaskets are a pain in the butt since you ahve to take off the intake plenum.
94 Newbie
08-06-2015 10:33 AM
itzmywife's
07-25-2015 04:55 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
andrewtexas123
07-14-2015 04:29 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: Suggestions...where's this leak in these pics
