this is a stupid question...
Old Nov 13, 2007 | 06:51 PM
Tacoma750's Avatar
Does a manual tranny take tranny fluid? Latley my tranny has been acting up. Its a 4 cylinder 5 speed tranny.
Old Nov 13, 2007 | 07:01 PM
LoneStarMac's Avatar
yep, your right...
Old Nov 13, 2007 | 07:02 PM
Tacoma750's Avatar
iknow the transfercase takes gear oil, but im not sure about the manual trannies.
Old Nov 13, 2007 | 07:03 PM
BC_4runner's Avatar
there is no such thing as tranny fluid
There is assorted types of ATF(For Automatics and some standards)
All stanadard toyotas ive seen take 80w90gear oil
Jay351's Avatar
They take gear oil.
preferebly Redline MT-90 great stuff, highly recomended for your tranny and t-case.
Old Nov 13, 2007 | 07:05 PM
Tacoma750's Avatar
ok....so the manual tranny uses gear oil, just like the transfer case? What weight should I use?
Old Nov 13, 2007 | 07:15 PM
Jay351's Avatar
80w-90 like "BC 4runner" pointed out
Old Nov 13, 2007 | 07:19 PM
Tacoma750's Avatar
cool. Is there one place to pour the gear oil in? or do the tranny and tcase have seperate fill holes?
Old Nov 13, 2007 | 07:29 PM
Jay351's Avatar
They have seperate fill holes. You can use different oil in each but guys usually just do both in the event that the seal fails the oils wont contaminate eachother.
jason191918's Avatar
they are seperate. both diffs, tcase and the tranny all take gear oil (GL5, 80-90, 85-90 (check your manual)). All of these should have 2 big plugs (15/16") one is for filling and and one is for draining.
Old Nov 13, 2007 | 07:32 PM
Tacoma750's Avatar
cool im gonna do this tomorrow. I have a slow ongoing leak, and i need to refil them
Old Nov 13, 2007 | 07:35 PM
what is leaking (and where). As far as filling, just pull the fill (top) plug, get yourself a squeeze bottle and maybe a hose and fill er till she comes out. don't do this in your dad's garage...he'll get ...
Old Nov 13, 2007 | 07:45 PM
Tacoma750's Avatar
i cant even track the leak..i THINK its the seal between the tranny and Tcase. That cross member seems to get a lot of oil on it. It just helps rust prrof the undercarriage ;-) lol
Old Nov 14, 2007 | 10:10 AM
Shoua's Avatar
Don't use 80w90! Use what Toyota recommends, 75W90. What difference does that little bit make, you ask. HUGE. I just filled my transmission with 80w90, and in the cold that transmission sucks! It's not as smooth as the recommended oil. So I changed it out immediately to Redline full synthetic 75w90. Wow. It's about $10 per quart, and you'll need about 3 quarts, but it's damn worth the $30. Good luck!
JUICE222
Oct 13, 2015 08:50 AM
voiddweller
Oct 2, 2015 07:47 AM
PNW94Runner
Sep 29, 2015 02:55 PM
Rickstwowheels
Sep 29, 2015 02:23 PM
Odin
Sep 24, 2015 04:38 AM
