Stumped on '88 22Re Misfire Real Challenge
Old 05-16-2006, 08:08 PM
rfich53's Avatar
Question Stumped on '88 22Re Misfire Real Challenge
'88 22re misfire code 51. A/C idle doesn't step up when A/C on. Begins to "miss" after slight warm up. T/E1 doesn't step down idle. (Symptoms appear to beTPS) Tested ALL items listed under trouble code tested "Good". Then began changed out one at a time ALL components listed including ECU, TPS, A/C switch, A/C amplifire. Also tested "GOOD" air valve, EGR, Water Temp sensor, start injector time switch.
Gave up for tonight. Thanks in advance for any help much appreciated.
stock87yota
07-31-2015 10:08 AM
boogiewoogie
07-24-2015 05:10 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: Stumped on '88 22Re Misfire Real Challenge
