stripped distributor bolt
Old 10-24-2010, 03:46 AM
Rusted Rooster's Avatar
Hello again, Anyone have advice on a stripped distributor bolt hole in head.
Its the 12mm hold down bolt hole for distributor. Got bolt out, hole too stripped to hold. thanks.
Old 10-24-2010, 03:58 AM
1987 22re
Old 10-24-2010, 06:07 AM
wyoming9's Avatar
Red face
Use the thread replacement of your choice .
It is the same size as the thermostat housing M8x 1.25
A good size for these vehicles.
Good Luck
Old 10-24-2010, 03:53 PM
thanks wyoming9 picked some up today, never used them before, any advice?
Old 10-24-2010, 03:59 PM
wyoming9's Avatar
Red face
You want to make sure to use the proper size drill bit.
Sometimes the kits come with them some times they don`t.
only drill as deep as you need to .
make sure to use the correct length bolt.
take your time you will be ok
Never seize on any bolts going in aluminum
Old 10-25-2010, 12:15 AM
Thanks again, will repost when done.
Blamalam
03-12-2022 07:34 AM
nonstop
7
08-11-2015 09:26 AM
Flossy
08-05-2015 05:14 PM
upongame619
08-01-2015 12:12 AM
Quick Reply: stripped distributor bolt
