Stock '93 on 33/10.5 BFG any others?
The 33x0.50 didn't rub with the stock bumper either. I did have to trim it to clear the 34x9.50 TSLs I ran offroad for a while. It was very easy to trim, or you could just remove the lower valance. The point is that they don't get into the firewall, fenders, or frame - all of which would be much more difficult to rectify.
While my 4Runner is indeed not stock regarding lockers, gears, rear suspension and armor - the front suspension, ride height, and fenders most certainly ARE BONE STOCK.
Being that you have obviously never met me or seen my rig, how about you check out the THOUSANDS of pictures in the link below showing you that 33x10.50-15 works on 2nd gen 'runners with no lift.
Strange how at stock height I rub with 31x10.50's and 4" BS on 15x8's. If I put 33x10.50's on I'm sure I'd have to trim a bit more to keep from rubbing off-road. I guess I have the oddball 4Runner with a smaller fenderwell than yours......
1 Post
Dude, can you read? Obviously you have an aftermarket bumper and I'm suuuuure you've trimmed the pisss out of it to get those to turn without rubbing on the trails. Jesus, why do you have to argue about something so dumb? I made it pretty clear that a "STOCK" 4Runner isn't going to clear 33's WITHOUT rubbing. Your 4Runner is obviously NOT stock.
#25
1 Post
You would rub if you went wider, not taller. Think about it, and stock backspacing is 4.75" I run 3.75" Backspacing with 33x12.50's at stock height for a while, and they hardly ever rubbed..
#26
Dude can YOU read? Apparently not, because it is the common knowledge on this website, TTORA, ToyotaNation, etc... That you CAN run 33x10.50 Tires, on stock backspaced wheels, on ANY Toyota 4Runner or Truck from 1979-95, Get real, or Get outta here. Don't argue against factual information.
OMG are you guys breeding in the same house? Seriously, read what I wrote and tell me exactly what you're saying is wrong. WTF is wrong with you guys?
#27
Saying you can throw a set of 33's on your completely stock 4Runner with no rubbing off-road is false. That's all I'm saying. Stock suspension and trimming? Yes, I NEVER argued that fact. Thanks.
#29
1 Post
My point exactly. I never said you couldn't, I said you couldn't without rubbing unless you trimmed/hammered(please read my posts). My god guys, chill out. This is ridiculous.
#31
1 Post
Well guys, I fit 35x12.5 tires on my 1990 4Runner. All it needed was for me to bend the pinchweld a little bit in at the firewall. Nothing else rubbed, therefore, I completely believe that 33x10.5's will fit.
Now mileage and power is a different story.
#32
#33
For my own personal information, was this off-road or on-road when you weren't rubbing with 35x12.50's on stock suspension? What offset rims?
#34
Location: Yotatech, because Pirate is too expensive. NorCal.
#37
So with stock BS I can clear a 35x12.50 by just bending the pinch weld?
I'm asking because I don't know. You don't have to get all pissy and throw a fit over it. It just seems weird to me that by adding .75" BS I can clear such a big tire with no modifications on a stock 4Runner.
#38
1 Post
Yup, higher post count=higher intelligence.
#39
1 Post
And as far as your opinion on that, TC has wheeled more places you ever will in your life, and has a damn nice rig, he knows how to wheel, and what works, and what doesn't. I'd take his advice over most peoples, He's got the right idea Lockers+Tall SKINNY Tire+Armor=A well balanced truck with a low COG that can crawl its way through anything.
#40
