STILL trying to deal with my idle issue...
#42
lol, alright
allow me to start with the good news and the bad news, then I'll get to the even worse news
the GOOD news is that I found out what's making my truck run the way it's running
the BAD news is that it wasn't the IAV
I got out today and started on getting the IAV off the TB
the screws were a PITA, but I managed to get it off there
I took a look at it, and noticed it looked fine, but I did the ol boil-test, and sure enough, the plunger pushed out a little like it should:
I cleaned it up and bolted is back to the TB, and bolted the TB back to the upper intake.
I already had plans to put my stock intake back on, so I went ahead and took care of that while I had it taken apart too. The main reason for this was an obvious leak at the AFM adapter:
So I reassymbled everything and crossed my fingers... but she still ran the SAME way
SO, I thought I noticed what sounded like a little random valve noise while the engine was running and I had my head under the hood. So I proceeded to pull the valve cover to investigate.
First thing I noticed is that under my valve cover is dirty too
But just doing the ol jiggle test, none of the rockers were loose to the point that they would cause tapping I mean I didn't test them for clearances or anything, but they seems to be right where they needed to be.
And just then, right as I was about to clean around the edge of the head to put the valve cover back on, something cought my eye... the even worse news...
[YOUTUBE]http://www.youtube.com/watch?v=mOU54oQBGQM[/YOUTUBE]
yep... I don't think any more explaining is needed...
soooooo, it look's like I'm doing a timing chain replacement... a good one with metal guides...
on a good note, I made my valve cover pretty again while I had it off
#49
I'm glad you figured it out but I can't help but wonder why Toyota didn't use metal guides to begin with. I guess they figured 200,000 miles was about as long as they'd last............
#50
the front main's got a slow leak and has put a light coating of oil all over everything in the front of my motor and if I'm going to tear in there, I might as well replace the oil pump too, just for assurance, cause I've no idea how old it is. Might put a high volume one in it... why not...
wouldn't hurt to replace the whole timing cover too; cause there's 2 broken off studs in it right noew, lol. Maybe I can work those loose though
and yeah, my entire engine bay is nasty, lol
#53
yeah, I'm thinking about doing a whole group or things all at once now; the timing chain, oil pump, and front main seal
#54
hey the LC's metal guided kit comes with front main, right? that is what I'm seeing there, right?
http://www.toyotacatalog.net/M1WebGe...4-69F9E446E60D
the only other gasket I'd have to get is the water pump it looks like
and my water pump's got a lifetime waranty here localy, so I might just exchange it for a new one and get the gasket with it for free
#55
Here's all the gaskets you'll need:
I don't know if LCE sells a non conversion, single chain replacement kit with everything. They might, just might have to call.
#56
that link I gave IS the single row replacement kit I'd just have to get the oil pump separate, no big deal
I'm wandering if now would be a good time to upgrade the cam too
anyone have any experience with LC's cams? I'm eye-balling the EFI Pro/Street Performer Camshaft - Offset : http://www.toyotacatalog.net/M1WebGe...A-58B44B30DF84
#57
Yup, that link is right for the single timing chain only kit. I was more thinking of an ENTIRE kit that's like thier dual chain conversion kit that has a new timing cover, oil pump, water pump etc.
#58
maybe if I were to put in one of their stage 2 or 3 cams, and installed stiffer spring... but with stock springs, I don't see the point, IMO
I'll get the new water pump and the gasket for it for free under warantee, cause I'v got connections no really, they'll let me do it anyhow, cause it's a lifetime waranty part a standard flow water pump should do good; get something too much more and it'll probably push water through the radiator too quickly, so it wont have time to cool down good enough, and will probably cause over-heating; a lot of people don't realise that
but their hopped-up oil pump would be a good upgrade for a motor pushing 300k
see I had plans all along for a new motor and everything, but the more I think about it, it might be a waste of money
sure the motor's approaching 300k, but it's really not showing it. it's not burning oil, but it's got a few minor things that need tending to, like this timing chain now, the leaking front seal, I think the rear main may be seeping, but it also needs a clutch soon too so I could do the rear main then as well
so for less than $600-$650, I think this 22re will push 400k, maybe more!
lmao, oh and read the new revised sig
#59
well I really don't feel the need for the dual row chain, for me anyway
No, you're right, I would go with the single chain kit and go from there and double check the timing cover to make sure it's in good shape. I think your motor will make it to 400k!!! I had my motor completly rebuilt and overhauled(had no choice really, you know, spun rod bearing and all) and went with that LCE kit. I did notice a difference with the new oil pump and water pump. Never had an overheating problem unless I forgot to turn my fan on!!
#60
Floppy timing chain?? Sounds like a personal problem!!!
yeah I have no lower-end noise at all (that I'm aware of). no knocking, and I'v never ran it low on oil (who's to say the PO didn't, but what can ya do about that, ya know), so I'm not worried about any scaring of the main bearings and such.
when I do the timing set though, I'll drop the pan and get a good hold of the connecting rods so that I can make sure there's really no major play in them. do you think main and rod bearings could "carefully" be replaced with the engine still in the truck? I would think the most PITA part about that would be keeping the pistons from sliding out the bottom, lol. but I don't think I've ever heard of that being done before
