steering slop
Old 06-04-2007, 05:01 PM
ztrahp@bellsouth.net's Avatar
steering slop
i'm replacing the 3vze in a '92 4x4 xcab sr5. while the engine is still out, i'd like to do something (if it's worthwhile) about tightining up the steering. it's kinda loose.
any information would be greatly appreciated.
thanx,
ztrahp
Old 06-05-2007, 02:25 AM
dcg9381's Avatar
You need to figure out where the slop is first. It could be worn ball joints or other direct link components.
The steering box does wear over time and has an adjustment nut on it. Confirm that the slop is in the steering box before attempting to adjust it. It's a simple lock nut and adjuster screw, but as it wears the center position will be more loose than when deflecting it.
Old 06-05-2007, 03:32 AM
steering slop
thanx for your expertise. i'll check it out.
Old 06-06-2007, 12:06 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Personally, I doubt it's the steering box. Not saying it isn't, but if your rig has not seen a lot of off-road abuse those things rarely go out. The ball joints are pretty stout, too.
I'd suspect something like your idler arm or tie rods ends first. Even then, tie rods foremost.
Old 06-06-2007, 01:13 PM
InternetRoadkill's Avatar
The pitman arm on mine was the culprit.
Old 06-06-2007, 01:16 PM
norcalsvx's Avatar
at our shop for $22.50 we put it on a rack and see what your problems are on my truck it was ball joints and idler arm
ladybugRC
458
08-21-2020 10:41 AM
live4soccer7
05-11-2016 06:52 PM
scott90
10-04-2015 09:21 AM
ktm192k
10-01-2015 08:47 AM
gentry
09-28-2015 06:16 AM
Quick Reply: steering slop
