| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Steering Relay Rod Recall (PROBLEMS)
__________________
91' 22RE 5Spd 4WD left hand drive "Hilux Surf", a.k.a "4Runner". I currently use & abuse: MSD 6A Bosch Super Plus PermaCool TrueFlow EdelbrockIAS Cragar Soft8 BFG 31" A/T Optima Dynomax RoyalPurple ALPINE RFosgate KappaPerfect Stinger - Half the worlds supply of zip ties. "She'll make point five past light speed. She may not look like much but she's got it where it counts, kid. I've made a lot of special modifications myself." H. Solo |
#2 (permalink) |
The same happened to me when I replaced the rancho I had before the recall with a procomp after the recall. The nut wasn't hitting but the threads from the bolt was so I cut off the the minimum amount of threads and now there is no problem.
__________________
92 4Runner SR5 V6 4X4 Skyjacker Nitro shocks, Pro-Comp steering stabilizer, clear bumper lenses, lund windjammer, OME standard coils, ISR mod, inlet pipe removed, Bushwaker Fender Flares. 2002 Tacoma Prerunner V6 Xtracab. Lund Intercepter bug guard, rear glass sunshield, Bilstein shocks on rear. 2004 Honda CRV EX stock belongs to wife. |
#3 (permalink) |
I won't be able to cut any threads off cause there's not much left after the nut is on. I forgot to mention that who ever did the work at the dealership stripped the threads off the mounting bolt and the castle nut. So I either have to get a new bolt or buy a new Stabilizer with the bolt as a kit.
I'm wondering what brand of stabilizer could just bolt up and be fine after the recall??
__________________
#4 (permalink) |
You may be able to turn the bolt around so the head is where the nut is now.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#5 (permalink) | ||
Mine did the same thing. I just ground down the bolt head.. I only had to take maybe 3/16" off. THere's still plenty of bolt head left.
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#6 (permalink) |
No, this bolt is a specialty piece of hardware because the stabilizer bushing rests on a smooth surface and the diameter is bigger then the diameter of the threads. In short the bolt can only go one way.
__________________
| Tags |
| 1985, 4runner, 8695, 90, arm, hilux, problem, problems, recall, relay, rod, steering, toyota, truck, wore, yotatech |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Alignment issues after Steering Relay Rod Recall | Gator | 86-95 Trucks & 4Runners | 10 | 10-16-2007 08:26 PM |
| GOT MY RECALL DONE (Steering Relay Rod) | keithguts | 86-95 Trucks & 4Runners | 21 | 05-01-2007 05:03 PM |
| Steering rod relay recall | Bejiita | 86-95 Trucks & 4Runners | 3 | 03-08-2007 05:57 PM |
| Steering Relay Rod Recall | QuietGiant | Newbie Tech Section | 8 | 06-24-2006 06:51 PM |
| Steering relay rod replacement safety recall notice | cccp | 86-95 Trucks & 4Runners | 12 | 03-09-2006 10:25 PM |
