starting trouble/ electrical or ignition?
Old 06-06-2013, 12:56 PM
justinleebuckley's Avatar
I have a 94 Toyota 3.0 v6. Truck will start and run for a second then
It looses fuel pressure and dies right after. After doing this 2 or 3 times
The truck will crank and run perfectly. But if you turn it off. Repeat the
Process. Is it something with the ignition killing the fuel pump?
Or something else. Replaced fuel pump still same problem.
Please help
Old 06-06-2013, 01:14 PM
Scrussanation's Avatar
Please help
have you searched the forum on here... i recall seeing an abundancy of similar post and sure you should be able to get an idea where to start...Its how i fixed lots of my own problems lol
Old 06-06-2013, 01:34 PM
Team420's Avatar
have a look here
http://lmgtfy.com/?q=I+have+a+94+Toy...es+right+after
But... I'd start with checking out your v.a.f.m.
Old 06-06-2013, 01:39 PM
Originally Posted by Team420
have a look here
wow i like how it even does the search for you thats awesome
Old 06-06-2013, 02:00 PM
scope103's Avatar
"Starts and runs for a few seconds" is the classic sign of a problem in the VAF-COR circuit. Very easy to diagnose: jumper FP to B+ in the diagnostic connector. With key-on, the fuel pump will run. If that corrects the symptom, you have a problem in the VAF or COR.
Don't drive around with the jumper in. If a collision breaks a fuel line, the pump will continue running, spraying you with gasoline as you struggle to get out. Sound like something you want to happen?
MO transplant
04-23-2023 11:58 AM
coryc85
09-09-2015 06:24 AM
Yota.Jay
07-23-2015 08:08 PM
msane99
07-11-2015 08:08 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: starting trouble/ electrical or ignition?
