spool or not to spool
do this.
off road isnt hard on a weld job its the pavement thats hard on it. it cost me about 4" of flat bar mild steel so probly less than 5 bucks. just make sure yo u got mild steel in there cause welding that britle gear metal wont work if you go larger than 31's it will probly crack
lunchbox may also be good since it doesnt see much driving time
if i were you id spool it or weld it
do this.
If off road only and trailer queen then spool it, otherwise go with a lunch box locker. You'll be happier with the locker on few occasions you do drive it on the road. Besides, it's fun to watch peoples faces when the locker is banging around in the back.
I've got one in my samurai, and it sometimes bangs or clacks real loud when it unlocks abruptly....after a particularly loud episode, my sister looked at me a little frightened and asked "Is your rig ok?" I responded with a freaked out look and said, "dunno." LOL.
#25
i had a spool in my 2wd... gettin the air, and i have a lock rite in my 4runner. the spool was much easier to drive with. it was more predictable. the lock rite is weird. plus talk about people looking. when your in a parking lot and you take a corner and your chirpin, it turns heads for sure.. people are like "wheres the crawler" lol
#26
1 Post
yeah tell me abou tit lowlife lol as for alex did you take that picture of my 3rd when i welded mine? cause boy that looks just like what mine does!! witch i might be taking the 3rd from the trial rig and throwing it at the dd just for winter!
#27
I've got a lockrite in rear and like it, quirky to learn to drive at first. I'll never go open again. Haven't hade a spool but cringe when I hear them chirping tires when turning sounds like money down the drain when I think of tire wear v/s cost. Shoot weld it for cheap now save, and get another 3rd and do it right with gears, tires and locker at same time. just my 0.02
#28
69Stepside, I suggest you read the write up in my signature below, then smack yourself in the head for even thinking about ruining a perfectly good set of tires over a $200 locker.
Yehaw, 3000 posts!
#29
thanks. i actually had a buddy do it for me cause ive never done one. he stuck some axle shafts in there while he welded it, said that was real important. also said the reason the gear to gear welds dont work is cause the metal gets really britle and just wont hold, you need some mild steel in there so it has somethin to grab on to. 1/4" flat bar in there
priest16
15
08-06-2015 07:43 AM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
crawler#976
03-06-2015 10:48 PM
