So, I'm THIS close to finishing up my V6 caliper swap and....(stuck)
Old 11-06-2012, 12:15 PM
Philbert's Avatar
Actually....
Just looked at Corax's write up again and his are done like mine (opposite of yours):
http://www.expeditionportal.com/foru...4Runner-Brakes
Old 11-06-2012, 02:25 PM
rworegon's Avatar
Actually.....
The FSM shows the clip positioned as SCToy indicated in his photo at least in the FSM I looked at.
Old 11-06-2012, 02:59 PM
Philbert's Avatar
Originally Posted by rworegon
Actually.....
Well, shoot......hmmmm. I guess I could haul out my FSM too and take another look....sigh.
Old 11-06-2012, 04:57 PM
SCToy's Avatar
The reason i did it the way i did was because as you roll forward the rotor spins from the bottom to the top of the caliper, you don't want any parts to be pulled into thr assembly. If you attach to the top, then loose end of the clip is down has a chance to be grabbed into the assemby if something were to go wrong.
At least that is what i was thinking when i did it.
Old 11-06-2012, 08:23 PM
  #25
rokblok's Avatar
Two things-
-First---it shouldn't take very much pressure to compress a piston, IF the bore is clean and the piston and o-ring seal are in good shape. Its very easy to get a piston crooked in the bore... Are these new calipers or yard specials?
Second-- SC, where did you get those slotted rotors?
Old 11-06-2012, 08:58 PM
  #26
SCToy's Avatar
Hey, got those from tire rack, search for t100 rotors, they don't make them for the pickup. The only difference is they are 5mm thicker than standard rotors. I believe you need late model v6 calipers as well. I had already poached my calipers for my 81, so i bought rebuilt (i used 95 t100 as a reference model) ones at napa for like 45 bucks a piece plus i used my old solid axle ones for a core.
  #27
250000_yota's Avatar
If I'm not mistaken, their powerslots, like mine.
Would have gotten them from summit, but the were out of stock for a while. I can't remember where I got them.
-edit- scratch that...I'm a few beers in and those aren't powerslots. Now you got me curious SC...what kinda rotors you got?
Old 11-06-2012, 08:59 PM
  #28
SCToy's Avatar
No, those are ATEs, not power slots i believe. Check tirerack to confirm.
Old 11-09-2012, 08:12 AM
  #29
Philbert's Avatar
Thanks Rokblok. These are used calipers from another memeber on the board. They were on his 95 4Runner and working before he parted out. Had been off the truck for less than 6 months.
Old 11-09-2012, 08:17 AM
  #30
Philbert's Avatar
One more thing....
So, I've done brakes before but never replaced the MC/pads/calipers/rotors all in one job.
I have everything mounted up, wheels on, and poured in some brake fluid to the MC to get things started (didn't have time to bleed yet...maybe this weekend).
Anyway, I poured in some brake fluid to the MC till it was at the full line, then pumped the brake pedal a few times to get it into the system (I know there's going to be air and I'll have to bleed it). However, there is pretty much zero pressure on the brake pedal and the MC remains at the "full" line.
Keep in mind this is a brand new MC, and that I lost a lot of fluid when I disconnected everything, so my system is pretty empty.
Can someone suggest the proper way to do this, get that fluid into the system, get some brake pedal pressure back, so I can bleed this sucker and start road testing?
Thanks!
Old 11-09-2012, 08:22 AM
  #31
TNRabbit's Avatar
Those rotors are on the wrong side; slots should be angled the other direction.
Old 11-09-2012, 08:28 AM
  #32
TNRabbit's Avatar
Thanks!
I highly recommend using one of the vacuum brake bleeders. WELL worth the cost~
Old 11-09-2012, 08:39 AM
  #33
Actually, their not. I even called centric, the company that makes them to verify. The technical assistance rep said that that particular part number does not have a directional vane, so mounting direction is not imprortant. I mounted them the direction the stickers stated. I could have run them the other way, but I decided to just go with the stickers and be different. Trust me, I've had ALOT of people point out their mounted the wrong direction, but I've put almost 5000 miles on these rotors with no problem.
Old 11-09-2012, 08:46 AM
  #34
Philbert's Avatar
Thanks TN Rabbit - I've used vacuum bleeders in the past...but my issue is that the MC is full right now, and I have ZERO pressure. I can't add more since it's full. Wondering what I need to do next.....open a bleeder valve on a caliper and pump/add fluid?
Old 11-09-2012, 08:50 AM
  #35
Did you bench bleed the master? Cause it sounds like there is air trapped in the mc. It wont build pressure or allow fluid to pass if their is air trapped in the mc itself.
Old 11-09-2012, 08:55 AM
  #36
Philbert's Avatar
Nope. Like I said, the MC part is new to me.
I'm going to google that now, unless it's easy and someone wants to take pity on me
Old 11-09-2012, 08:59 AM
  #37
Lol sorry. Google can probably give a better explanation than me, but I will say you should be able to do it without removing the mc.
Old 11-09-2012, 10:02 AM
  #38
Philbert's Avatar
Thanks guys - came across this YT post from 7 years ago that I think sums it up:
https://www.yotatech.com/forums/f2/b...ylinder-51409/
I also have the old brake lines that came with the donor calipers, so I may use them to re route back into the reservoir if the thumb method does not work.
PS - the bench bleeding guides all mentioned pushing in the piston and letting it out...but my brand new TG 1" MC came with the piston fully pushed in and flush to the mounting bracket....not sure how it would "let it itself out" in this exercise...hmmmm
Stay tuned!
Old 11-13-2012, 11:46 AM
  #39
Philbert's Avatar
Update (and more questions)
OK guys-thanks for all the help along the way on this - really made a difference!
I was able to bench bleed the MC while in the truck - used old brake lines and some 1/4" clear tubing to feed back into the MC reservoir, and just pumped the pedal/added fluid to MC until no more air came out.
I just ordered the Motive power bleeder to do the rest before I road test it. Have folks coming into town this weekend so this will probably not wrap up till then....
That said, what's concerning me now is the wheel bearings. I followed this 5 step guide on Youtube (think it's a member here?) for his 94 4Runner front brake job and wheel bearing replacement:
http://www.youtube.com/user/eturkov
However, I noticed his bearing/hub set up was pretty different from mine.
I took mine apart carefully and put it back together as it was before. I did not torque anything to spec because I didn't know to at the time. I also didn't do the "pre load" thing because I didn't know what that was and I don't have the spring tool to measure. I can borrow a 54mm socket from a guy here at work.
Basically, I'm wondering if I will be fine since I took apart the hub/bearing assembly, then put it togther as it was. I need to torque appropriately and do the pre load thing too, I know.
Here are some photos of the disassembly to give you an idea of the hub setup on my auto hub SR5 87 4Runner:
Here are all the parts:
This is the spindle after the hub was removed - instead of what's in the youtube video (the tabbed ring where you bend tabs to lock in place), I had this ring piece of steel with 9 holes in it, 3 of which had small "hex" screws to hold it in place (think allen nuts but star shaped). There was a star/spline interior washer (which you see below, right next to my camera, which I think was held in place with that smaller c-clip snap ring, just to its left. The auto-locking spring mechanism (just to the right of the screwdriver) I took apart by mistake on the first one I did....I got it back together thank god, and left the other side intact when I tore it down.
I guess what I'm wondering about is:
1) Do my bearings/hubs even have a preload setting, since it uses that star-nut locking ring and c clip snap ring to hold the star washer (star being the spline pattern on the inside)? I didn't remove the inner bearings since I just wanted to get the rotor off for this job. When doing the pre load test/torque of 54mm nut, do you want the front hubs engaged or totall free?
2) What do I need to do to ensure I don't screw up my bearings/etc on a road test (the truck is still sitting in my garage)?
3) My FSM didn't appear to have torque settings for:
- hub plastic cover
- hub itself
- spindle nut (in the middle of the rag in the photos below -gold)
- rotor-to-hub bolts
Old 11-13-2012, 12:11 PM
  #40
SCToy's Avatar
You will still need to seat the bearings in their races straight and preload them so they don't kill themselves. Too much play or too tight is bad. Actually, in the pre 85 section toyospearos solid axle rebuild thread has a simple method for seating the bearings, which are the same for IFS and SA trucks.
Quick Reply: So, I'm THIS close to finishing up my V6 caliper swap and....(stuck)
