Slapping/Clanking
Old Nov 12, 2007 | 07:27 PM
Justinvd's Avatar
Slapping/Clanking
1988 Automatic 4runner. 22R-E
Recently my 4runner developed a slapping noise when i put it in gear. the idol is a bit high so it jumps a bit when put in D and especially in reverse or lower gears. Its like some sort of clank or something, hard to descrive, just sounds like there is alot of slack on the driveshaft then it just tightens. The U-joints are both good though so if anyone can suggest something i would be very thankful?
JvD
Old Nov 12, 2007 | 09:26 PM
just a 22re's Avatar
do it and have someone look at your rear end and the drive shaft to be sure about that
Old Nov 12, 2007 | 09:28 PM
Justinvd's Avatar
Thanks for the input
Old Nov 13, 2007 | 07:10 PM
84sr5yoty's Avatar
Probably bad u-joints. Just replace them all if you end up doing it. I'd strongly suggest replacing the center bearing at the same time if have one. Get the driveshaft balanced too.
Reduce you idle to 800-900 RPM's. Harshly engaging the trans into gear will reduce its overall life expectancy, not to mention the driveshaft and differential.
